I have bought Lenovo Y410 notebook in Feb 2008. After one month, i found its CD/DVD rom is not working for any cd or dvd. Then i give to my local vendor. He solved this issue in 3 - 4 days. Now same issue is coming again. Again any cd or dvd not working.So pls help me out how can i solve this issue.
A few solutions: 1. Have you tried to clean your cd/dvd lens? Probably your lens is getting weak.
2. For advance user: Locate, and then click the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318} - Look for DVD/CD-ROM drives and delete the subkey. - Restart your machine.
3. Let Microsoft FixIt help you: http://support.microsoft.com/mats/cd_dvd_drive_problems/en-us
Worst case - Get a new CD/DVD-ROM for the replacement.
The CD/DVD Driver is an Operating System generic Driver and it can be re-installed from the Device Manager. Please press with Window Logo and the R Keys on your Keyboard to open the Run window, then type devmgmt.msc and press the Enter Key to open the Device Manager. After that, on the Open Device Manager window, please click the "Actions" menu and select the Scan for Hardware changes option. This will re-install the CD/DVD Drive Driver in the Computer.
Hope this helps.
Please let me know if you have any questions or require further assistance.
hi! just a tip hope it would work! try to delete the upper and lower filters.
2) Click on Start, Run, and type REGEDIT and press Enter 3) Click on the plus signs (+) next to the following folders
* HKEY_LOCAL_MACHINE * SYSTEM * CurrentControlSet * Control * Class * {4D36E965-E325-11CE- BFC1-08002BE10318}
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
* UpperFilters * LowerFilters * UpperFilters.bak * LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete 6) After deleting the keys, close the Registry Editor 7) Reboot your computer
hope this helps!!!! goodluck!
Y510 uses the slot loading DVD, right? It's not software problem... that Matsushita DVD drive on Y510 and Y410 are faulty... they work only for a few months then always have trouble burning. I've seen many complaints on Lenovo support forum... I'm having the same problem with my Y410 too... I had to use USB to install Windows 7.
it looks like you need an update for your DVD driver (Optiarc drives )
use the lenovo support site to get the latest driver for your notebook, http://lenovo.com/us/en/index.html
you might need to re-install the cd-burner driver (nero). suspected also could the your dvd-rom drive faulty. contact your service center to replace your dvd-rom drive.
pls try this take out the dvd from drive u will see a shiny eye like thing it is lens try to clean it in circular motions with very soft cloth used to clean lcd's and then try those dvd 's otherwise u have to get the drive replaced ur lens is weaken due to some faulty media and excessive use it is a normal wear and tear process
