SOURCE: how to remove door panel 2008 pontiac g6
2008 g6 sedan i want to remove drivers door panel?Curt.
SOURCE: EVAP canister and Purge valve leaking locate hoses
Not sure I understand. The Evap and lines leak. Do you need to know the location? If there is a problem, do you still have a warranty with GM?
SOURCE: how do i check the transmission fluid on a 2008
There are quite a few types of cars on the road with sealed automatic transmissions like your Pontiac. Yours will have a plug screwed into the front of the trans near the coolant lines. It has an 11 mm [7/16] head. Unscrew it then check the level by finding if the fluid is to the hole. It's topped off by removing a cap on top of the trans and adding fluid until it starts to run out the hole, with the engine off. Your owner's manual will list all this.
SOURCE: locate the tire pressure sensor on 2008 pontiac g6
The tire pressure sensors are part of the valve stem, one in each tire. Please check the tire pressure in each tire also the spare. If all are correct then you will have to diagnose the system with a scanner at a GM dealer or a name brand tire store.
SOURCE: when do I replace the timing belt and water pump
The timing belt last for a while. Probabbly change between 100,000-120,000. The water pump dont need changed until it is broke. When so, your heat wont work or your car will overheat.
You call a mobile lock-smith
