Sporadically the power vent continues to run hours after the water has reached desired temp. I shut off the switch, turn it back on and then it will be ok for a day or so.
The auto switch is probably sticking. They are sometimes mounted to sense the vent door open or some are heat sensitive turning on when the flame comes on and heats it up to a certain temp. Check that the moving parts on the switch are not sticking. If everything looks OK you may need to replace the switch.
Hi David Peterson, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Make and model?
RHEEM Model 21VP40-1
