Dryers Logo
Earl Thompson Posted on Mar 12, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Want to fix power cord but cant figure out where a green wire goes from cord
Steve
Level 3:
  • Master 696 Answers
  • Posted on Mar 12, 2015
Steve
Master
Level 3:
Answers
696
Questions
Helped
239463
Points
55809
Hi Earl
The green wire from the cord goes to a secure connection on the junction box.
This link and video will tell you all you need to know.
Hope this helps you out.
-Steve
Wiring Dryer Power Cord
robert
Level 3:
  • Dryers Master 2,548 Answers
robert
Dryers Master
Level 3:
Answers
2548
Questions
0
Helped
870585
Points
8043
I'm trying to wire in my new kobalt 60gallan single stage belt drive electric air compressor. I have run the wires from the circuit box but cant figure out where the wires go and the manual doesn't tell...
half the wires go on one side and the motor wires on the other, ther are letters next to the terminals look it up on google to what wire goes were, but most i had delt with is motor cord is on the side away form it and the wires go red top blue/brown/black on bottem then green on the other corner of the same side then on the other side of the switch goes the same for the main power cord
Need wiring schematics for Haier HWR12XC5 AC
My friend ... you are doing a simple repair ... you don't need a wiring schematic to replace this power cord. When you get the unit open ... you will find the other end of the ripped cord ... black goes to black, white goes to white green goes to green or ground. In fact ... you will trim the end of the cord and reattach it using either crimp connectors or wire nuts.
Thanks for your interest in FixYa.com
2answers
I need to change out my 3 prong dryer power cord with a 4 prong dryer cord, but unable to figure out where the wires go on the new 4 prong power cord, because the one on there is grey and not color coded...
Changing from 3 to 4 wire hookup on a electric dryer:
Power cord help for 3 & 4 prong dryer cords
This is an example of a three wire connection dryer cord hookup. Notice that there is a ground strap connected from the common center terminal to the frame of the terminal block. Place the center wire of the cord on the center terminal [ one with the ground ******** it ] and the other two wires will be placed on the outer terminals and it doesn't matter which wire goes right or left. Get the center wire of the cord right and you are in business.
This is an example of the 4 wire dryer cord hookup. Notice that the ground strap has been removed from the terminal block frame and folded back onto the center terminal for storage. You can see the colors of the other hookups. TIP: White always to the middle.
Below are a few websites.
http://www.applianceaid.com/general.html#3to4
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=10&newsdesk_id=5
Lights
The standard color codes used by most American car manufacturers in the older days were as follows: green - right turn signal, yellow - left turn signal, brown - tail lights. Of course, brake uses yellow and green. I'm not positive if it's the same on that particular car, but that is the standard.
2answers
I NEED HELP CHANGING CORD TO A 4 PRONG ASAP!!THANKS
These two pictures illustrate the power wiring on a the terminal of an electric dryer. The one to the left here is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown to the right. These are just just thumbnail pictures that you can click for a larger view. But I'll bet you already figured that out, didn't you?
Besides the number of wires in each cord, there are two important things to notice. First, in the four-wire configuration, notice that the dryer's grounding strap is folded back on itself. The whole point of the four-wire cord is to separate the ground from the neutral. The green wire (the "new" extra wire in the four-wire cord) is attached to the dryer cabinet. In the three-wire configuration, the grounding strap is left intact and the neutral and ground are tied together.
tn_3prong_dryer_outlet.jpgtn_4prong_dryer_outlet.jpgIf you need to re-wire the outlet, these pictures will explain the anatomy of the three-prong (left) and four-prong (right) outlets. Once again, these pictures are just thumbnails--click 'em for a larger view.
Sure hope this helps you find a resolution to your delimma! Best wishes.
Comments: Jul 23, 2009- bf71290.jpgfb4d3ed.jpg
Three wire Four wire.
Better? Best wishes and sorry about the pics. Hope this is better.
Top Dryers Experts
john h
