Motorcycles Logo
N
Neil Wallace Posted on Mar 10, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 1980 rm125 and I have a 140 main jet on it is that the right jet or if not please tell me the right stock jetting.
Ewnerd Nasalo
Level 3:
Master:
  • Master 359 Answers
  • Posted on Mar 10, 2015
Ewnerd Nasalo
Master
Level 3:
Master:
Answers
359
Questions
0
Helped
63148
Points
1063
You should really have the workshop manual if you are working on the carb. Not only will this tell you the correct main jet size, you will also get the pilot jet size, mixture screw, and jet needle positions. All of these should be checked if you're taking apart the carb yea?
How to tell which needle and seat go to which carb, factory stock?
Manual says - VT 1100 88-96 main Jet both nr.165, slow Jet 42
For VT C2 and 1100T main front 175, rear 180 , slow 42
For 97 main both 178 , slow 42
You can read Nr. on Jets, they are small
2answers
JETS HAVE BEEN MISARANGED THATS UNDER THE DIAUFRIMS/CANT TELL WHICH GOS WHERE?
Hi unless some one changed the main jets they should all be #110 mains, the diaframs and needles if stock are all the same.
Hi My XR 600 - 97, was taken off the road last May 2010 -I have purchased it in Dec 2010, and have slowly been restoring it. However yesterday when i took it for a spin, it was not reving smothly,...
Black smoke indicates a too rich fuel mixture. Be sure the air cleaner is clean. Install a new spark plug. Check what size the main jet is. The prior owner may have installed a larger than stock main jet. There will be a number stamped on the side of the jet. Call the dealer and ask what the stock jet number is for your bike and then tell them what you have. Go back to stock.
1helpful
Hi,just got a dynojet stage 1/3 kit for my 1980 honda cb650, it's on standard air box, but 4 into 1 exhaust, I take it I should use the stage one kit. Also I have no instructions can you help...
Intended for motorcycles with a stock engine using the stock airbox, air filter and stock pipe. Stage 1 kits are fully adjustable to allow the use of a well designed aftermarket pipes and stock replacement air filters like K&N. Stage 1 kits are designed to improve throttle response and driveability and in most cases power increases of approximately 5% throughout the entire power range can be achieved.
STAGE ONE INSTRUCTIONS
1. Remove the vacuum slide from the carbs. Remove the stock needles & spacers, noting the order of
assembly. Locate the slide lift holes (Fig. A), with the slide drill DD# 14 supplied, enlarge your slide lift
holes. The picture may not show your slide exactly, enlarge your slide lift hole or holes depending on your
model. Do not drill any new lift holes. Do not drill the needle hole.
2. Install Dynojet needles on groove #4, using all stock spacers. Install the Dynojet washers (2 per
needle) above the E-clip.
3. Remove the stock main jets and replace with the Dynojet main jets provided. If you are running with
stock exhaust, use the DJ110 main jets. With an aftermarket header or slip-on with high flowing baffles,
use the DJ116 main jets. Be sure that the jets you are changing are the main jets.
4. Locate the fuel mixture plug (Fig. B), if you see a screw head, proceed to adjusting procedure. With the
DD #5/32 drill bit provided, carefully drill thru the plugs. Note: the mixture screw is directly underneath this
plug, be ready to pull back on the drill the instant you break thru. Use screw provided to secure and
remove the plug. Carefully turn mixture screws clockwise until they seat, turn out 3 turns.
For further info on this, visit: http://www.dynojet.com/jetkits/motorcycle/honda.aspx
You can find the manual for the model you are searching for. Follow the 1st column "CC" to find 650cc models and you can find your specific model after that.
Thanks for asking.
Regards,
Arvind S Iyer
4helpful
What,s the reason for my honda crf 100 sparkplug getting so dirty all the time i need to keep cleaning it to get it to fire everytime can anyone assist on this problem please help????????????????
The bike may have the wrong spark plug in it. The stock plug is NGK, CR7HSA. You may want to go to a hotter plug > CR6HSA. It is also possible that a prior owner installed a bigger main jet. Check the main jet size. The jet will have a number stamped on one side. Stock is #92. A #98 jet would be a richer jet. Please rate my answer. Thanks.
I have a 1998 Kawasaki 1500 Vulcan Classic. Which jets do I change if I'm changing my exhaust? What are the stock jets?
you need to change the big main jet. the stock size will be stamped on the jet. Go for one or two sizes bigger. Your motorcycle shop dealer will help you out when you buy the jets.
1helpful
I have a 2002 cr 250r stock carb and pipe live in lower nh what should i be running for jets
your factory jets should be ok with stock carb and exhaust,unless it came from way down south or someone changed them.factory jets are main jet #380,pilot jet #30
1helpful
I have a GSXR 750 1990 model and would like to know the std jetting sizes
The stock main jet is 127.5. The stock pilot jet is 32.5 The stock jet needle is 0-8. The sizing on the needle refers to the taper in diameter.
Rf has race can K&N and dyno jet fitted when i got it, but terrible flat spots all over the place. can you give me a clue what size of main jet to use
No one can tell you what jet size to use unless they know exactly what exhaust and jets you have now. The best thing for you to do is go back to a known good configuration. If it has never run right since you had it, go back to stock (make sure it runs right with stock settings now!) and start your adjustments from there. Change one thing at a time and do performance testing between each change. Dyno runs are best, but timed runs might work too, depending on your application.
2answers
Re jet the carburetors
Carburetors supply a mixture of gasoline and air to the engine. The gas comes out of little things called “jets” (usually a pilot jet needle jet and main jet). If you modify your airbox or exhaust to flow more freely you get more air going through your system. This often means that there is not enough gasoline so the engine runs badly. “Rejetting” means replacing or modifying some of these jets so as to supply gasoline differently than stock, usually more gasoline than stock. If done correctly, this allows your engine to generate more power, run a little cooler, start and run smoother and get worse mileage. ,,,
Top Motorcycles Experts
Arnie Burke
Arnie Burke
ADMIN Andrew
ADMIN Andrew
Are you a Motorcycle Expert? Answer questions, earn points and help others
