Cell Phones Logo
A
Anonymous Posted on Mar 02, 2015
How do I get my phone to stop saying "Verizon Wireless" every time my phone rings?
wensch00
Level 3:
Master:
  • Master 346 Answers
  • Posted on Mar 03, 2015
wensch00
Master
Level 3:
Master:
Answers
346
Questions
Helped
84529
Points
1120
Try this: Settings>Sound & Display>Remove the check mark beside Roaming Tone. Sorry if this doesn't work. I Goggled "Samsung Cell Phones How do I get my phone to stop saying Verizon Wireless every time my phone rings". If not, go to Samsung.com and ask if there is a way to remove the phone company identification.
How to reset my verizon pageplus phone?
Contact Verizon Wireless support and they will unlock it for you.
If you need further help, reach me via phone at https://www.6ya.com/expert/scott_843b43f7ebebd3f5
Jul 19, 2014 • Cell Phones
Why does my driod go right to voicemail
It could be that the phone is delayed in ringing. Try placing a test call and see how many times it rings in the phone you are calling from before it rings on the phone. Then you can determine if the phone is delayed in ringing. If you hear ringing and the phone rings once and then it goes to voicemail then there may be a setting on your phone that is causing this.
Mark
Motorola Support
What does it mean when they say you can flash a phone from one company to another example flash from Verizon wireless to cricket?
"Flashing" is the process of rewriting EEPROM (electronically erasable and programmable read-only memory). In this case, it means you can reconfigure your phone so as to stop paying Verizon for its use and start paying Cricket instead.
Aug 19, 2013 • Cell Phones
How can I change the number of rings before the voice mail starts
This is actually set by the provider.
Verizon Wireless for example sets it for 30 seconds (or about 6 rings).
Some providers can change the amount of time, and others can not (depends on their system).
This can seem different to the enduser, because if the phone is not connected to a tower or if there is a hiccup, it may only ring once or twice on the phone itself.
Activated new verizon phone, it will not ring. goes straight to voice mail.
i think they failed to activate it the rest of the way take it bakc and say hey this wot ring they can fix it in an instant
1helpful
Each time a call comes through, it audible states: verizon wireless. Went to the verizon shop today and less than helpful person went into sounds settings and put it on "ring only" in caller id readout. ...
You need to go to the Menu option and than go to Sounds, Go to Service Alerts and than go to Call Connect and turn that to Off and go to ERI and turn that to Off. That should solve your problem.
1helpful
2answers
Incoming calls ring 3 times at main extension, then phone stops ringing at main & rolls over to ring at all other phones. Phone rings once at those extensions before going to voicemail. (We have...
Your voicemail thinks that it is ringing six times. The time that it takes to transfer to the extensions counts. Whiloe it seems that there is a lapse the system actually is using enough time to ring six times total. If you need longer ring time at the extension, take in account the transfer time and set it to pick up after 8 or 9 rings. It will actually only ring six. You just have to trick the system a little.
Jul 22, 2009 • Cell Phones
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
