Tried to update firmware and now all I get is a blue screen with the word Magellan across it and a black line across the bottom of the screen. how do I fix it?
You can try to update your GPS firmware.
Before you update your Magellan eXplorist 500 firmware or install a custom basemap, Magellan recommends that you backup all of your GPS data.
Click here to download the firmware update (Version 2.57)
Connect your Magellan GPS unit via the USB drive. Double-click on the update file to begin the installation process. Follow the on-screen instructions .
i did post a clarification request to you, but i dont think they are working...do you still need help...i can help you..please see my feedback if you have any doubts!
Magellan® RoadMate® 1200 Software Update Version 1.50/3.12 - Release
Notes
This update applies to Magellan RoadMate 1200. It includes the
following features, fixes, and improvements:
Improvements:
Point of interest (POI) Search Improvements reduce POI search times
Map Draw Improvements improve zooming, panning, and time to display
the map
The software update version corresponds to your current software
version:
If you have software version 1.46 or 1.48, your software will be
updated to v1.50.
If you have software version 3.10, your software will be updated to
v3.12.
You can locate your software version by following these steps:
Start at the Main Menu.
Press the arrow on the bottom right of the screen.
Select "User Options"
Select "System Settings"
Select "Next"
Select "Product Information"
Your software version is on the line titled "Firmware Version"
i asked yesterday what for error message were you getting, but you havent replied so maybe you missed it. the dos box you are refering to is part of the update process for the 3100. run the update again and be patient, this update is huge and takes about 30-45 minutes to complete.do not remove usb cable untill directed to do so then the unit will reboot numerous times to install the update. do not attempt to touch the gps until you see the screen with the time zone. if that fail hopefully you copied the files before you tried to update it. if the update fails again, let me know and ill show you how to restore your 3100
You probably just need to reset it.
Magellan Maestro models- the location of reset button is on the left, right, or bottom side inside a small hole. Use an object to apply pressure to depress the reset button. Also try holding the power button down for up to 10 seconds to power the unit off and again holding the power button down for up to 10 seconds to power the unit on.
You may need to update your firmware. Go to this site http://www.magellangps.com/support/
select your product family, model, and then press the submit button. Firmware updates are located in the updates/upgrade section.
This should solve the problem. Good luck. If this helps, plz rate it fixa. Thank you kindly.
try to press the reset button on the left side next to the usb port with a small paper clip or toothpick and see what happens and chk on the magellan website to see for firmware update if it is do it and plug in powersupply and the usb and leave it alone and let it reset a few times until it says to unplug from the usb .also make sure it has a flash sd card in it so you do not lose your addresses.let me know what happens.
