Tablets & eReaders Logo
A
Anonymous Posted on Feb 24, 2015
What is wrong when gmail does not respond?
I am using an android tablet. Gmail responded at first but does not respond now.
Dan Castro
Level 2:
Champion:
  • Expert 329 Answers
  • Posted on Feb 24, 2015
 Dan Castro
Expert
Level 2:
Champion:
Answers
329
Questions
0
Helped
49680
Points
430
There could be many reasons why. Does the tablet have a good wifi signal? Did someone inadvertently change the url, your username and/or password?
Maybe you can try it on another device (computer or smartphone) can you still get in?
1helpful
Turned tablet on as usual. Opened my gmail but the tablet refused to respond refuses to turn off. Seems like it needs to be reset but I have no idea how to do it. Thx Harry Nichols
I am not an expert on these things but I suggest you check your manual. I think you could find details of the reset procedure that might involve pushing a wire paper clip or similar through a tiny hole in the casing. I apologise in advance if I am wrong.
tip
Android Tablet Hard Reset Method
If you had forgotten your Pattern lock of your Tablet, you can reset it of your own.
You can recover it through your Gmail account, enter the pattern for 15-20 times. After it you will be asked to enter your Gmail password.
But, if you do not remember Gmail password
then Hard reset will be the Final solution to your question.
Different Hard reset factory wipe methods for Android Tablet Different Hard reset factory wipe methods for Android Tablet
1helpful
Unable to log into gmail.account with my passward.What is the reason.
click on forgot my password and change it. Someone might have stolen you password.
Tablet is not responding ,to any comands
Touch Screen Not Working Android Problem [Fix] - TechKhoji
www.techkhoji.com > Android
Feb 27, 2014 - How can I reboot my tablet, the touchscreen is not working. ....Sometimes when I turn on the screen it doesn't respond to my fingers. Then I ...
Android Tablet Touch Screen Problem Solution - YouTube
? 21:36
https://www.youtube.com/watch?v=h7_aqvkfKL4
Jun 16, 2014 - Uploaded by SOLOMON BOTCHWAY
I CANT Believe it, i Actually fixed my tablet.. all i did disconnect the ... my touch is working how to fix the screen not showing? ....2 WAYS TO FIX IPAD TOUCHSCREEN NOT RESPONDING - WORKING - Duration: 5:17.
Samsung galaxy Tab S 10.5 not responding by touch ...
? 2:54
https://www.youtube.com/watch?v=XkK9zCx46gs
Jul 7, 2014 - Uploaded by Linkhunter
i just the new tablet by samsung i recharge the tablet after that isnot responding by touch and so Sim card do ...
Touch Screen Not Responding ' DaniWeb - DaniWeb IT Discussion ...
www.daniweb.com > ... > Hardware > Mobile and Wearables
I forgot my parten to unlock my tablet which is running android os 4.0 help me please
If you use the wrong pattern often enough, Android will ask you to login to the tablet using your Google ID and password (the one you use for Gmail and your calendar). This should allow you to access the tablet and from there you can set a new pattern.
Factory reset
Hold the power button down and the volume button down until the icon comes up then a menu will come up choose factor restore. If you still have problem let me know
Android tablet problems
Try going to system settings and select 'About Tablet' then checking you are fully charged and in good wifi signal select 'system updates' Update to any new version it finds.
Make sure it is fully charged with the screen brightness down (so it will last for hours, just in case). The last thing you want is a power down during an update...
I can not open my attachments in Gmail
Check your gmail mail settings on the iPad. It seems you may have the wrong settings because typically your mail server settings would be set to "pop.gmail.com" when using Gmail on an iPad.
Hope that helps!
Cannot send an email on gmail from my Samsung Galaxy SII tablet.
What model is your S2 Tab and what is the Android version? Thanks.
Top Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
