Ovens Logo
A
Anonymous Posted on Feb 24, 2015
How do I get rid of the rust on my appliances?
Rust on the handles
Barry Coates
Level 3:
  • Stoves Master 3,463 Answers
  • Posted on Apr 02, 2015
Barry Coates
Stoves Master
Level 3:
Answers
3463
Questions
Helped
1407066
Points
12766
Remove rust with sandpaper, or wet and dry paper.
Then touch up with with the appropriate colour enamel paint.
HOW DO I GET RID OF F11 ERROR ON FRIGIDAIRE ELECTRIC RANGE MODEL ES305
Hey Kenneth, I understand that you are receiving an "F11" error message on your Frigidaire Electric Range. Before considering contacting a service provider, I would recommend resetting the range by turning off the power to the appliance for about five minutes. After the five minutes return power to the appliance, this should allow the appliance to return to working condition. At this time if you find the problem still persists, you may want to consider contacting a professional technician. The concern could be the control board. Hope this helps! -JK
1helpful
Oven door handle has broken. Model TKC 1255/2/SS. I am unable to find a supplier who stocks spares for this - can you help
Try ebay, or thefind.com. Otherwise, some appliance recycle locations may have a used. Or a handy repair man may be able to fashion a repair or wooden replacement. If you still have the parts, and somewhat DIY inclined, JB Weld Epoxy and a metal threaded rod or similar reinforcement in a hollow handle may be the fix.
Mar 26, 2015 • Ovens
My covers that go over the gas burners are rusted and i can't find where to get new ones
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Jan 30, 2011 • Ovens
Door Handle coming loose
Hello,it would depend on the brand of appliance,its model number and how it was designed.In many cases the door may have to disassembled to access screws or nuts holding the handle ends.If the end caps which the screws or nut fasten to are stripped,the handle may need to be replaced.
Thanks
May 27, 2010 • Ovens
1helpful
How to replace the grill element in a Stoves 720EF double oven?
1) Isolate the unit by turning the power off at the main switch.
2) Remove appliance from housing unit.
a) When handling the appliance care should be taken to ensure the outer frame trim is not damaged.
b) The appliance is secured into the housing unit by 2 screws through the top corners of the front frame, open the doors and unscrew the 2 corner screws.
c) Grasp the bottom of the frame, pull forward and out onto a suitable surface.
3) Unscrew the top and rear panel securing screws and lift the panels clear.
4) From the rear of the appliance, pull off the 4 (top) grill element leads and the earth lead.
5) From inside the oven unscrew the 2 screws from the grill mounting plate.
The above is from the Handbook. I assume from point 5 the element is then free to be removed. reverse the procedure to fit the new element.
If you want a copy of the Handbook, then I will need an email address for you.
1helpful
Enamelware repair
I have used appliance touch up paint to repair scratches and chips on ovens on enemel with out any problems.
I do not think you will have a problem
I do believe that there is a specific touch up for white enamel, but I don't know about other colours
Please leave feedback.
Thanks.
Nov 13, 2009 • Ovens
2answers
Hotpoint double oven
Top oven works bottom oven fan works but bottom oven does not work and cannot get rid of auto signal
Top Stoves Ovens Experts
ZJ Limited
ZJ Limited
vince
Are you a Stoves Oven Expert? Answer questions, earn points and help others
