Cell Phones Logo
S
Shela McIlravy Posted on Feb 08, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The speaker icon is always on my screen so when I call or answer the phone it is on speaker phone mode. How do I get it off so it doesn't go directly to speaker phone all the time.
I have looked through every file to see how to get the speaker of the screen and there is nothing that directs me to it.
Brett Duxbury
Level 3:
  • Cell Phones Master 4,352 Answers
  • Posted on Feb 08, 2015
Brett Duxbury
Cell Phones Master
Level 3:
Answers
4352
Questions
0
Helped
1120430
Points
13423
What is the make and model number of the phone.
Are you using the phone while placed face up on a table as some phones go into speaker mode when placed on a table or you might have the sensor covered with a phone cover and the phone thinks it is on a table face up.
Can not answer income calls, does not ring
Press phone icon. Then press the 3 dot icon upper right screen. Press "settings" . The TTY AND Hearing Assitance functions must be in "OFF" mode. You will now be able to answer and to hear calls.
2helpful
Sound is not working on tour9630
Internal speaker sound volume is controlled by the rocker switch on the right side - directly below the headset jack. This will control both the private listening mode volume level and the volume of speaker when Speakerphone (or MP3 audio) is selected. The speakerphone mode is toggled on and off by pressing the "$" key (to the right of the "M" key).
Ringer volume is controlled by first selecting one of the seven customizable profiles under the speaker icon on the top left of the screen (below the battery gauge). Move the cursor to highlight the speaker icon and press the track ball. Choose the desired profile: Normal, Loud, Medium, Vibrate Only, Silent, Phone calls Only or All Alerts Off. Repeat the process - but this time scroll all the way past the profile list - and choose "Edit Profiles" instead. Here you can select the profiles one by one (or even add a new one) to customize them to your liking. You decide the sound, volume,etc for all the alerts for each profile. It provides a huge amount of customizing choices.
Finally, you can freely download the 314 page Blackberry Tour 9630 User Guide to learn about all the functions and tips using the phone.
Please rate my reply if it was helpful. Thanks and good luck!
23helpful
2answers
How do i turn off the silent mode on a uniden phone, ive held down the # sign and nothings happening
Silent Mode
You can silence the ringers on the base and all handsets for a specific period of time; the answering system answers any incoming calls without playing anything through the speaker.
With the phone in standby, press and hold # on any handset. The phone prompts you to select the number of hours (1 - 9 or Always On) that you want it to stay in silent mode.
To confirm, press # or just wait about 5 seconds. The phone turns on the answering system and displays Silent Mode On on each handset.After the selected number of hours, the phone automatically exits silent mode. To exit silent mode manually, press and hold # again.
If the phone is in silent mode and you turn off the answering system, the phone exits silent mode.
Multihandset Features To use the features in this section, you need at least 2 handsets.
Your base supports a total of 12 cordless handsets: the one that came with the base and up to 11 DCX160 accessory handsets.You must register accessory handsets to the base before using them. (Handsets that came packaged with the base are already registered.)Handsets that aren't registered display a Not Registered message. For registration instructions, see p. 18, or see the accessory handset manual.If a handset was ever registered to a base, you must reset it before it can register to a new base; see p. 18, or see the accessory handset manual.Conference Calling
When an outside call comes in, two handsets can join in a conference call with the outside caller.
To join a call that's already in progress, just press Talk/flash or SpeSpeSpeaker.To leave the conference call, hang up normally; the other handset remains connected to the call.
26helpful
2answers
How do I turn off the speakerphone on my rumor 2?
You have probably noticed that you can place or answer calls by pressing either the green "TALK" button or the "speaker" icon right above the green "TALK" button.
When you press the icon, the phone is in speaker mode. When you press the "TALK" button, the phone is in earpiece mode. Be careful about which button you press.
5helpful
2answers
The headset icon always appear in my nokia n70 and cannot remove and when i connect my headset ... it doesn't work . with or without headset the headset icon always appear in my screen . During incoming...
5helpful
HOW TO REMOVE HEADSET ICON IN MY NOKIA N70
maybe you had your phone wet on the bottom part where the headset is to be plugged in. bring it to the nearest repair shop for the just to clean the metal contacts then, your icon will be gone
7helpful
4answers
Take phone out of silent mode sgh p520
PUSH BUTTON ON LOWER RIGHT HAND CORNER OUNCE.
PUSCH SPEAKER BUTTON ON LEFT HAND UPPER CORNER FOF MORE THAN 2 SECONDS
May 21, 2008 • Cell Phones
3helpful
2answers
Silent mode problem
There is a small speaker icon on the top of the screen press and hold this and ot should come off.........
Headphone icon
in mobile there is network problem
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Cell Phone Expert? Answer questions, earn points and help others
