Corrupted firmware. A firmware update is necessary. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
SOURCE: Dynex dx-pdp42-09 screen went black; won't turn on or off
dont really know,would you be interested in selling it lik that?
SOURCE: When you hit the power button, the light turn blue
check 2 1000MF 16V Capacitors on power supply.
SOURCE: TV will not turn on. Power indicator light is red
You either have the power supply module or back lights inverter board problem, need to narrow it down.
Please see my basic troubleshooting guide here:
http://s807.photobucket.com/home/budm/allalbums
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Parts: try www.shopjimmy.com or Ebay
SOURCE: samsung television wont turn on
there is a defect in your tv.there is parts on it shorted consult your samsung service center to fix your problem
SOURCE: Plasma Television won't turn on
Hi
A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
if otherwise the power supply board is faulty you can try websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Hope this helps
