please run channel auto scan will not go away even after a scan. its hooked directly to the cable...
(More)
please run channel auto scan will not go away even after a scan. its hooked directly to the cable line
three digit code for using in RCN Remote Controller Am using a Dynex 26'' LCD TV/TV-ACL/TV LCD 720 P...
(More)
three digit code for using in RCN Remote Controller Am using a Dynex 26'' LCD TV/TV-ACL/TV LCD 720 P Model DX-L26-10A RCN Uses RT-M1000+T/V-11 Remote Controller
Just Bought a 26" DX-L26-10C Dynex TV. Need the codes to get Telus TV hooked up PLEASE... telus...
(More)
Just Bought a 26" DX-L26-10C Dynex TV. Need the codes to get Telus TV hooked up PLEASE... telus does not have any codes for this brand of TV :(
I've had thid computer monitor for about a year and a half with no problems. One day I went to check...
(More)
I've had thid computer monitor for about a year and a half with no problems. One day I went to check something on the computer and found the monitor completely dead, no power button light, nothing that made it seem plugged in (but it was). I've since been using my old 15" monitor but I miss the larger one. Is there anything I can do to fix it? I've been on websites that have forums with people complaining about bad Gateway monitors. They say Gateway ignores their complaints. Some have said that the problem is blown capacitors and that when they replaced them everything worked fine. I'm not very handy (soldering is probably out for me) so how much would a repair like this run me? Would I be better off trash canning this monitor and buying a new one? You can be sure it won't be a Gateway. If there's an easy solution I'd like to hear it. Any help would be greatly appreciated (for example, are there any reliable, low cost monitors?).
The problem:Press the power button and the led turns blue, but nothing happens. I figured out that if i unplug the set then plug it back in it worked....
written by stiv0
Vizio Tv's have an extra menu that contains factory settings which you can change or fix should you have a problem with your TV.
Here's how to...
written by TechNerd
If an LCD TV has sound but no picture do the following: Use the source button to ensure that source is not set to the wrong input.
Try unplugging...
written by ginko
The first thing to check is the cables connected at the back of the TV.
Check cable connection, and try using a different cable, video signal
is...
written by ginko
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
The codes are at this website:( http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml ) Just put the...
All Polaroid flat panel I have a FLM-3203 32 inch LCD. After reading so many posts on replacing the to 10v caps I decided to do this to mine. After...
written by prowler21
When you have a damaged or unrepairable television it may seem like a total loss and ready for the trash. Instead of trashing the television, why not...
Most people just put their plasma TV on a stand on a table or other furniture. But what fun is that? One of the cool things about having a TV that's...
by wikihow
If you have an old TV but want to watch DVDs, you may have difficulty hooking up your DVD player. Most DVD players have a yellow RCA video output...
by wikihow
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
