SOURCE: 1998 Ford Explorer
had same problem when my rear wiper motor went out. I had to locate all the rear wiper motor fuses and take them out to stop it. Am now waiting to replace my wiper motor.
SOURCE: 97 Montero Sport charging voltage is high
It sounds like the internal regulator is faulty. If you are charging your battery with 15.5 volts, the battery will gas extensively and suffer from overheating. The normal charge rate for a normal flooded battery is 14.2 volts. A vehicle designed to have a calcium battery will have a slightly higher charging voltage but not 15.5V. The regulator is generally in the back of the alternator (depending on make and model) and can be replaced particularly if you you remove it from the engine. Smacking it with a hammer will not mend it.
SOURCE: Idles rough upon start , goes dead when letting up on gas.
If the bat went dead and was disconnected it can take 25 to 50 miles of driving for computer to reset sensors and controls. Sounds like MAF Sensor maybe reading different than when it was first driven. Did you drastically change climates or altitudes, New readings from when it originally was put into service. Slight changes in temp, alt and other variables gradually reset, if driving does not improve within 50 miles it will need diagnostics.
SOURCE: My neighbors 04 Mazda Tribute intermittantly needs
There is certainly a short somewhere. Most dealers will not take the time to find a short, they are in the business of selling parts. I would find a local mechanic that has a electrical specialist on staff to find the problem for you.
SOURCE: 1996 Dodge Ram won't start
run another test on the starter...they are about 20/80 bad/good right out of the box!
