I have a sportage 2008 ans experiencing 1-3 seconds lose of power then the car picks up again. Happening once a day at least at low revs in third gear, Kia cannot find anything wrong worried that it c
Car done less than 50 k miles serviced by Kia braintree.
I assume your car is an automatic. First check that the oil level is correct. If it is low, the transmission will slip in the way you describe. If the oil level is OK, then the transmission is faulty and will need to be overhauled.
Sorry, i cant really provide a solution without more details..
But i would say check the transmission fluid (assuming its an auto, since you said when it shifts)
If your transmission fluid is low, add some, then "Cycle" the fluid.
Start in your cars lowest gear (L or 1?) and keep it there for like 15 seconds. Then move up to gear 2, then (3?) or "D", then "N", then "R" then "P" with 15 seconds in between. The whole time your doing this, your holding the brake, and not moving. Your going from the lowest gear you can pick, to park. if your car has the manual mode and doest have "1 / L" or "2", put it in manual mode, keep it in first gear, tap to shift to second, and if it lets you go any higher, go to third, fourth, etc. with 15 seconds in between..
Do this anyways and see if it helps haha.. Good Luck!
