I have tried checking windows firewall....norton360 settings ...ran scans...from SlimCleaner Plus and Malwarebytes...tried system restore...nothing has helped...this has gone on for about a week...my computer using Vista often gives message of "high CPU usage"....have run out of ideas to fix the problem... please suggest any other solution, if possible...THANK YOU
SOURCE: My computer doesn't turn off
I don't quite understand ya question exactly... However I think I have found wat ya need. Please find below some Shutdown troubleshooting links to help with ya problem... www.aumha.org/win5/a/shtdwnxp.php www.theeldergeek.com/shutdown_issues_in_xp.htm
SOURCE: Vista infected trojan??
If your CPU usages is high, check in your task manager which process is using that much CPU.
Please post the process name here.
I probably can tell you whether it is spyware or not...
SOURCE: Windows Vista Installer corrupted/freezing
if you are sure that there is some problem in windows installer then you can download the windows installer from the following site and try installing it ....
http://www.microsoft.com/downloads/details.aspx?familyid=5A58B56F-60B6-4412-95B9-54D056D6F9F4&displaylang=en
and if you couldnt able to install in the normal mode then just go safe mode and try installing the windows installer ....
then the problem will surely be solved
you can go to the safe mode by pressing F8 at the time of the system boot ....
after pressing F8 you must choose the safe mode ...
thank you
bye
any doubts you can reply me
i am always here to assist you
rate my solution
SOURCE: I'm on windows Vista trying to play Lexulous goes
you could right click on lexulous and select compatibility mode and try xp and see if that works. I have done that with some of games and that seems to have fixed the problems I was having
SOURCE: Problem in windows Media center "unknown Audio Error 80040155"
I am really sorry sir the command is
regsvr32 wmp.dll
