To reverse an upside-down picture on your SEIKI TV, you can try the following steps:
Press the "Menu" button on your SEIKI TV remote.
Use the arrow keys on your remote to navigate to the "Picture" menu.
Scroll down to the "Picture Rotation" option and select it.
Use the arrow keys to rotate the picture until it is right-side up.
Press the "OK" button on your remote to save the changes and exit the menu.
If the above steps don't work or if you can't find the "Picture Rotation" option in the menu, you can also try physically rotating the TV screen by 180 degrees. This may be necessary if the TV was mounted upside down or if it was accidentally rotated.
Keep in mind that the location of the "Picture Rotation" option may vary depending on your specific SEIKI TV model. If you can't find the option, consult the TV's user manual or contact SEIKI customer support for further assistance.
You should have bought a remote that was made for your television. They are $20 and called Facsimile Remotes. No programming and an exact copy of the original. Universal Remotes are so 1980 :>D Remote Control Codes For SEIKI TVs SEIKI TV 3 digit remote codes: 564 627 000 505 ; SEIKI TV 4 digit remote codes: 4635 3953 4794 4346 ; SEIKI TV 5 digit remote codes: 12964 13559 13560 10178
SEIKI Remote Controls for which device type?
https://www.replacementremotes.com > SEIKI Replacement Remotes.com offers SEIKI remote controls for sale online including remote controls for TV, Blu-Ray DVD Player, TV/DVD Combo and many more.
Yes, buy a remote control :>) They are readily available, no need to program and can be obtained from Amazon, eBay and specialty remote retailers like www.remotes.com
Time Warner CableJun 5, 2013 - Does anyone know the correct code to use for programming the remotecontrol with the Seiki TV? ... The one they have listed for Time Warner is a 4 digit code(0178) so it doesn't work. ... I did some research and it appears LG or Samsung codesmay work for Seiki sets.
Jan 30, 2011 - 7 posts - 6 authors
I purchased a 32" Seiki TV but there is no listed remote codes for this brand. Does any one know of a code that will work? Thanks.
Sony remote control have no set-up codes to Seiki. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box. http://electro-medical.blogspot.com/ http://remotesearch.blogspot.com/ http://electrohelponline.blogspot.com/
Couple things here. A lot of the flat panels and projectors will shut down after a few minutes if no signal is present so I would not worry about that. The first thing to check is all of your connections and then check that your TV is on the same input you have the cables plugged into. Most remotes with have an "input" or a "source" button to toggle through the inputs.
