ION Audio ION FILM 2 SD 35mm Film and Slide Scanner USB Cable Logo
Jim Defoe Posted on Dec 31, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My scans look like a negative and not a photo
Placed the slides in the tray as the directions stated.
Jay Plesset
Level 3:
  • Master 2,942 Answers
  • Posted on Jan 01, 2015
Jay Plesset
Master
Level 3:
Answers
2942
Questions
Helped
668627
Points
9879
When you go to scan your slides, the software should have a setting for "slides", or "negatives". Make sure you select the correct one for what you've put in.
Which side of battery goes up
Usually, no matter how the carrier slides in, the battery drops into the carrier with the + side up.
Can not scan negatives and slides
Download this manual and select "scanning films and transparencies" section and follow the instructions.
https://files.support.epson.com/pdf/prv7ph/prv7phug.pdf
3helpful
2answers
I'm missing the slide tray for my Dimage Scan Dual IIl Would like to find one to buy.
I have the slide tray to a Dimage Scan Dual II and am looking for negative tray.
I would be perfectly willing to swap it with you or buy it off you...
1helpful
2answers
Hi, I have Canon Pixma MP270. IS it possible to scan photo negatives and change to colour prints. thanks. Blair
A multi-purpose printer scanner cannot scan negatives or slides.
You need a slide scanner or a flatbed scanner that is capable of scanning negatives and slides. Not all flatbed scanners are capable of scanning slides and negatives.
6helpful
Can HP psc 1410 PRINTER SCAN NEGATIVE AND SLIDES
Chances are that somewhere in your family photo collections you have a bunch of slides and negatives that you wish you could do more with. You may want to include them in your family history, to publish them on the Web, or simply to make digital copies so you can share them with the family.
If you've ever tried to scan a negative or slide on a regular flatbed scanner, you'll know that it doesn't work, and you end up with a pure black scan. In this article we'll show you how you get your negatives and slides into digital format, and what issues you may face along the way.
pixblue.gif Benefits Of Scanning Film
There are some key benefits to scanning film (we'll use the term to include slides and negatives) in comparison to scanning a photo. When you scan film, you can use the full area of the slide or negative, whereas a photo will generally only display a cropped portion of the original. You are also scanning the original source image rather than the color corrected and tweaked version of it that the photo processor has provided you with. The process of turning a negative image into a positive one involves inverting the colors in the image and removing the orange cast from the negative. This would be a complicated process if you were doing it by hand; however, your scanner will provide you with software to do this automatically, or you can purchase standalone software to do it.
Most cheaper flatbed scanners are designed to scan photos and other images that reflect light when it is shone onto them. The problem is that film is transparent and light passes through it rather than being reflected off it. Many flatbed scanners have an optional transparency adapter, which replaces the scanner lid with a larger box shaped ob....
Spare negative and slide holders for konica
There's a supplier on eBay ....
http://cgi.ebay.com/SH-U1-MINOLTA-SCAN-DUAL-ELITE-SLIDE-HOLDER-TRAY-/330348917237?cmd=ViewItem&pt=LH_DefaultDomain_3&hash=item4cea5471f5
Might be worth keying into your local ebay site, to see if there is something more local.
Jan 24, 2010 • Cameras
How to scan negatives & slides with the epson RX620
There are holders for the slides and negatives inside the top cover. Remove the white part and take out the holders. Place the slides or negatives in the holders and place on the glass plate. Then you choose the proper menu for copy or scan and follow the directions on the screen. I scanned quite a few slides and had no problem.
1helpful
Scanned negatives are not sharp.
One workaround is this: use the holder for the negatives as a guide but not as a holder as such.
To do this, place the film negative directly on the glass plate, then put the negative holder (completely assembled) on top of it; align the film and the holder so that the frames on the filmstrip line up with the marks on the holder correctly.
Now, close the lid and follow the normal procedure for scanning negatives. They're noticeably sharper this way, suggesting that the scanner's focus is set for items placed directly on the glass plate. I have no idea why focus isn't adjusted correctly for negatives, which site a millimetre or two above the glass.
Distorted Scans
it could be your not scanner in a high enough resolution. I believe negatives have a 1000 dpi.
Top ION Audio Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you an ION Audio Camera Expert? Answer questions, earn points and help others
