SOURCE: I need a new set of holders, FH-U1 and SH-U1
Found trays in real time from previous owner...
SOURCE: error 4 ... Konica Minolta Dimage Scan Dual IV
Use VueScan. A free trial is available so you can test it before you commit to buying it. Available for Windows and Mac.
http://www.hamrick.com
SOURCE: Can the minolta dimage scan dual III work with
Since Konica Minolta exited this market, they ceased developing new drivers for upgraded versions of Windows. The last version developed was for XP...so on the surface, it would appear that it may not work with Vista.
You may want to download the last driver version and try it. The worst thing that could happen is you'd simply uninstall it. You may also consider upgrading to Windows 7 and using the XP mode with it to use the Scan Dual III
http://ca.konicaminolta.com/support/americas/scanners/dimage-scanners/dimage-scandual_3/software_drivers/index.html
SOURCE: Dimage Scan Dual IV is it compatable with Windows 7 32 bit?
Right now, the Konica-Minolta site lists the scanner as discontinued and has no drivers for Windows versions later than XP. The Microsoft Compatibility site lists it as "Information Coming Soon" You can try the generic driver that Windows will try to install (check if you need TWAIN or WIA drivers) or download the current driver and try installing it with XP SP3 compatability mode (right click on the file, select Properties, then the compatability tab.
If those fail, there is another option in Win7 Pro or Ultimate. Download and install the XP mode from Microsoft (2 downloads/installs). Then install the scanner inside the virtual computer running XP that results. You may need to save images to external media to share them between the two computers.
I hope this helps.
