Oregon Scientific AWP131129 - AW131/AW129 Wireless Meat Thermometer Replacement Probes Logo
James Olafson Posted on Dec 24, 2014
I hav an AW131 and need to know how to change from C to F
Craig Smith
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Aug 18, 2015
Craig Smith
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1739
Points
Inside the battery compartment on the AW129 is a slide switch to change the temperature from C to F.
No current temp
Inside the battery case is a "reset" hole. Use a paper clip and push it in while the temperature probe is on. The screen will flash and the unit will synchronize once again with the probe.
8helpful
2answers
I have Model AW131 Grill Right wireless Thermometer. It shows no transmission signal no matter what I do. Any suggestions. It is brand new.
you are supposed to hit the RESET button within 1 minute of each other to sync the products together.
The reset buttons are inside where the batteries are on both units. Hit them withing a few seconds of each other and they will sync. Then you should see an antenna symbol on top left of the receiver's screen.
2answers
I have a 2001 durango .I just did a filter and fluid change on transmission and now it wont go in any gear. Somebody told me that the vehicle had to relearn itself . How and is it true?
try this first, drop it into low, ( foot on the brake of course), and work your way up through the gears a few times slowly, repeat this a few times, see if that doesn't help, your ****** has air in the lines, and needs to work them out more than likely,
I hav changed my os now and i need to know how i can instal the wifi and all the other drivers required for my laptop
If you do not have the drivers to match your new OS you will need to download them from the Dell site.
4answers
When making a left turn into a parking spot, just as I'm stopping the brakes start to pulse.
What it sounds like you are getting low speed ABS activation .Most common cause for this is a dirty magne.It could also be a problem in wheel sppedsensr,not sure if the are internal of the hub.
My Yahoo messenger doesnt hav call to buddy option but when
Humm. Thats something strange. Try uninstalling and reinstalling yahoo messenger. If the problem still persists then i think your OS is corrupted. Youll need to reinstall.
My memory stick is error????
i think its d probs f ur stick.... just give a try wid another stick if it doesnt hav ny probs den i think u hav a memory stick problem... Change it....
Unable to install software
i hav a samsung e250 mob i dont know hw to install games and softwares in my mob pls calrify the information anyone to me yar...note-i hav a ,jad .jar files its getting stored in other files i dnt know how to install this..pls do needfull soon..
Top Oregon Scientific Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you an Oregon Scientific Home Expert? Answer questions, earn points and help others
