Hi, I just submitted a refund on an item. It was a Seiki SE39HE02 39-Inch 720p 60Hz LED TV. I just hit the refund button and submitted it. Is there a way to change it to a replacement of the item inst
Want to know if I can get an exchange instead of a submitted refund. Actually I need to speak with a customer rep.
WalmartShop all · No-Contract Phones · Unlocked Phones · Prepaid Minutes & Data ..... Seiki 32" Class LCD 720p 60Hz HDTV, LC-32G82 ... 1-20 of 45 total reviews ... for an inexpensive 32" TV for our guest bedroom and came across this one and ... Walmart is sending me a replacement and if it works well, I will update my review.
WalmartSeiki 32" Class LED 720p 60Hz HDTV, (2" ultra-slim) SE321FB .... I bought this as a gift for my girl friends home bar...we were booth very happy with the tv.
? 1:42
https://www.youtube.com/watch?v=OZlNRxBe1fg
Feb 28, 2014 - Uploaded by Kevin Davidson
+Kevin Davidson Uhm how do I manually set my dns settings? ....Can u help me can u go on amazon and type in seiki 32 inch tv if its the same one as yours ... Can you help me purchase SEIKI LED SMART TV and would like to change .... Seiki SE50UY04 50-Inch 4K UHD 120Hz LED HDTV Initial Setup ...
most of the time you put the cable in the box, the box does everything for you , you connect the cable from the box to the tv, turn the tv, go to settings, go to channel select auto tune
I suggest you check the signal strength of the stations in question. It might be that the TV has selected them from a transmitter that is weaker than the main one. If this is the case you might need to do a manual tune on those stations to find the best signal. The TV should have a built in signal strength indicator so you don't need any special equipment. If you do a test of one of the good channels you will see how strong the signal should be.
check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
