The main cause to this problem it with its SMPS [power regulator board]. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
The computer enriches the fuel mixture and then leans it out to see fluctuation and changes at the oxygen sensor readings, these changes forth and back can often be noticed, also AC pumps cycle from time to time for short bursts just to keep them freed up i think. when the AC clutch kicks in the idle will also fluctuate, again it is normal to some degree. As for air pockets fill the cooling system there should be no air pockets at all nothing but coolant. Air does a poor job of drawing heat from the engine from the inside of a cooling system however it works well outside the cooling system.
This happens a lot. Your input power lines fluctuate a lot from time to time. You get lags and sags and spikes on the power line. The UPS is just telling you this. Nothing you can do about that. Your UPS is operating normally. You don't really want to put the UPS into bypass during one of these fluctuations do you?
shajuchy19, If the screen is fluctuating try plugging the power into a power strip. You can also try reinstalling the video card drivers to see if that will resolve the issue.
Thank You, Dell-Jesse L Dell Social Media and Communities
Had the same problem sometime back with same model of LCD TV, it has something to do with voltage fluctuation and has no easy fix that you can apply, have it checked out at a local repair shop...
Hello, how are you dear? i think you are fine. Dear your problem is very simple you cell screen is damaged change the LCD of your mobile. then its not fluctuates.
