Re: To move the zero right which way do I turn the dial...
There should be an arrow indicating direction on the windage adjustment turret (normally the right side) of the scope. If the arrow is marked left, turn the adjustment knob the other way to move the zero right. To move the bullet point of impact right, move the adjustment knob (dial) right.
Your model doesn't have a specific needle position adjustment. But you could try this - set it to the shell stitch or lingerie stitch on the stitch selector but leave the stitch width setting on zero, this may move the needle to the left most position with any luck.
Other possibility is to put it in a step of the buttonhole sequence, but again leave stitch width on zero and see if this moves the needle bar to the right or left for you.
NOTE: If your safe DOES NOT have a key, skip Step 3.
Turn the dial to zero.
Insert your key and turn it until the plunger pops out.
Turn the dial to the left (counterclockwise) three times to the first number of the combination (pass the first number of your combination two times, stopping on it the third time).
Turn the dial to the right (clockwise) two times to the second number of the combination (pass your second number once, stopping on it the second time).
Turn the dial to the left to the last number (stop the first time on your last number).
Pull the handle down; the door should open.
3 Digit Combination Locks for Security Safes 31-10-31
Insert the key; turn right.
Pull on the key while it's in the lock to open the door.
3 Digit Combination Locks for Gun Safes 31-10-31
Electronic Locks 31-10-31
Insert the tubular key into the lock to the left of the key pad.
Turn the key all the way to the right until the plunger pops out.
Press the five-digit factory code. The green Proceed light will come on.
4 Digit Combination Lock 31-10-31-10
Turn the dial to the left (counterclockwise) four times to the first number of the combination (pass the first number of your combination three times, stopping on it the fourth time).
Turn the dial to the right (clockwise) three times to the second number of the combination (pass your second number twice, stopping on it the third time).
Turn the dial to the left (counterclockwise) two times to the third number of the combination (pass the third number of your combination one time, stopping on it the second time).
Turn the dial to the right to the last number (stop the first time on your last number).
Are you sure that you are turning the dial correctly?3 Digit Combination Lock 31-10-31
Locksmith Instruction manual on how to dial open sentry fire safes. NOTE: If your safe doesn't have a key, skip Step 3. Turn the dial to zero. Insert your sentry safe key and turn it until the plunger pops out. Turn the dial to the left (counterclockwise) three times to the first number of the combination (pass the first number of your combination two times, stopping on it the third time). Turn the dial to the right (clockwise) two times to the second number of the combination (pass your second number once, stopping on it the second time). Turn the dial to the left to the last number (stop the first time on your last number). Pull the handle down; cracking Sentry Fireproof Safe open.
