follow this steps and fix it. God bless you
If there is no hot water, first push the reset button on the high-temperature cutoff; test the thermostat and replace if faulty (see below). Test the heating elements and replace if faulty (see below).
If there is not enough hot water, adjust the thermostat settings. As
needed, reset, test and replace thermostats and heating elements if
faulty.
If the water is too hot, adjust the thermostat settings and reset. Test and replace the thermostat or high-limit cutoff (see below).
An electric water heater is a 240-volt appliance that can deliver a fatal shock. Always turn off power to the heater at the electrical panel
before
beginning work, and verify that power has been shut off. Make sure
others in the house know not to restore electricity prematurely. If you
have any doubt as to whether electricity has been turned off, seek
professional assistance.
