Most of electric element is 1 1/2" socket. No need to hire pro , at www.bangslush.com they sell the element socket for only $ 14.95 with free shipping. The socket is especially engineer for 1 1/2" water heater elements, the socket not like other, the elements is snug fit for easy removal and replacement. it also snap on onto the socket the element will not fall off the socket
1-1/2" but it is much better to get a tool made to remove the elements. Sockets have a rounded edge and are not flat on the end. The element is so thin that the socket will not grip right. Once you get the edges striped off of the element then you are in deep do-do...
For a couple of bucks you can buy a tool at Lowe's or HD, or your local hardware...
Do the job right with the right tool for the job...
Heatman101
I did that...getting the special tool (8 bucks) , and even using a large pipe wrench on the special tool for leverage could not get it off. The hot water heater manufacturers apparently do no use any anti sieze compound or teflon tape on threads to prevent the threads from binding. They are so stupid....
Bob
Bob, how did you get it out???? I am having the same problem.. Please help!!!!
1 1/2 inches made by H&T TOOLS LLc
Hi, 11/2" is the size, but as stated already, you should get the specialty element socket from a plumbing supply store. they are cheap insurance. I have also used a "basin wrench" to remove them. Once the water is drained below the element and the wires are tucked out of the way, standing and facing the element, turn the attached wrench, counter clockwise to remove. If you cant budge the element, try this... I have used a torch flame, directly on the element itself. Be sure to clear away ANY wires and insulation before proceeding. heat the element with a small to medium flame, until the rubber seal behind it boils out, or about two minutes to start with. after cooling, tap the element with a hammer, then use the wrench to remove. Be sure to clean out the groove that the new seal will need to seat in.
SOURCE: WHAT SIZE SOCKET NEEDED TO REMOVE ANODE ROD?
Hello EDAN I believe it is 1 1/16" socket.I had 1/2" drive & extention bar as it very TIGHT & hard to turn the rod nut.
SOURCE: Electric water heater elements.
after you shut off electric and water and drain tank they are unscrewed. they make a large socket like wrench to remove i have also removed using a basin wrench
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
