H
I'm not a musician so am not familiar with. However I have found a manual on the Internet which is downloadable from here
http://assets.peavey.com/literature/manuals/72483_6844.pdf
Page 23 shows a very clear diagram of the back of the machine and description of the various input/output sockets, which should clear everything up for you. Reading other parts of the manual might also help you avoid trouble.
Cheers
SOURCE: where (does it have one) is the fuse on a peavey KB3
If a fuse has gone, it is likely there is an internal problem. Replacing the fuse without repairing the cause can cause further damage. If the fuse is not readily accessable, it is likely inside very near where the power goes onto the circuit board of the power supply.
SOURCE: hello. my names Stephen and
I don't know what you mean by rubber connect??? If you mean the conductive rubber contacts or "pills", just CLEAN them AND the circuit traces they contact with 99% isoprophyl alcohol and QTips. Do this GENTLY.
