Dryers Logo
Shari Bowden Dant Posted on Nov 05, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Whirlpool AccuDry Dry (Model LGQ8858JQ2). It will start fine, but will stop shortly into the dry cycle and beep three times. The drum turns and I checked the belt. The timer continues..but at
I have cleaned all lint trays and replaced the exhaust tubing just in the event that it was an air flow issue. On occasion the dryer will actually dry a full cycle...but it is VERY RARE.
Thomas Beaver
Level 3:
  • Whirlpool Master 2,119 Answers
  • Posted on Nov 05, 2014
Thomas Beaver
Whirlpool Master
Level 3:
Answers
2119
Questions
0
Helped
752142
Points
6319
I think that it's a door switch error.
Open the door and locate the door switch. Exercise the switch with your finger about twenty times then try the dryer again. You may have to replace the door switch.
Check youtube for help videos on replacing the door switch.
5 Related Answers
paultheguru
  • 21 Answers
  • Posted on Sep 08, 2007
SOURCE: Whirlpool Dryer GEQ9858J autodry problem
Are you running the dryer in a relatively humid environment?
Anonymous
  • 1028 Answers
  • Posted on Sep 14, 2008
SOURCE: gas dryer intermittently heats.
most likely solenoids after a few firings they tend to open up and not work again until after cool down replace both they usually come in a kit
docjohn174
john gagnon
  • 943 Answers
  • Posted on Sep 15, 2008
SOURCE: Autodry cycle never stops
hi thanks for the question ther is a thermostat on the air duct at the back of the dryer it has 2 wires at ends and 2 wires in the middle smaller ones this thermostat opens to turn off heat and the small wires on this thermostat when the heats shuts off then power goes to the timer and not before if it shuts off on timed dry timer is ok i would vacuum the dryer make sure all the vent right to the outside is clean as air flow restriction can cause this problem thanks the appliance doc
Anonymous
  • Posted on Feb 22, 2009
SOURCE: Maytag Atlantis MDG6400AWW does not stop on auto-dry. Heats fine and timer was replaced to no avail. Time Dry works.
jchow: I am trying to fix the same problem with the auto-dry on this model. If you have found the solution, could you please post it ?
Anonymous
  • 111 Answers
  • Posted on May 21, 2009
SOURCE: Dryer will not heat properly
Your heating element sounds like it is going out.
Dryer beeps during dry cycle
if the dryer is beeping on it's own most likely you have a bad board part WP8563974
What does beeping mean during dry cycle?
My dryer did the same thing, it was so distrubing noise in the middle of drying cycles, so I turned off the sound switch it went away, now it doesn’t peep any more.
What does beeping of dryer mean during dry cycle?
Depending on the dryer, it could simply be the wrinkle guard setting. This is the case with my Kenmore (Whirlpool) dryer.
Turn on power, the lights come on but when you press start nothing happens just a click sound.
Click sound at power button and start button should get it going. If not then Dryer drum is not turning.
When washing Machine goes into spin cycle, , it starts making a grinding noise and never goes to full momentum and starts to slow down, after the grinding noise. The clothes aren't fully dry as they...
Sometimes, a Whirlpool dryer may not function as you'd like.Although specific details vary by model, the company offers several generalguidelines to troubleshooting your Whirlpool dryer and getting it back intoworking order.
Verify that thedryer is connected to its power source if it won't turn on. Whirlpool alsosuggests checking your home's circuit breaker, as the high power needs of thedryer may have tripped the circuit. If the circuit has been tripped, reset itby flipping it back into the "On" position. Push the door of the dryer. Whirlpool designed its appliances to not turn onif the dryer isn't secured and notes that the dryer door may not be fullyclosed even if it appears shut. Push firmly at the top and bottom of the door,as some Whirlpool models have two latches. Press the "Start" button again. Whirlpool reports that some modelsrequire you to press and hold the button for five seconds to fully start themachine. Depending on the model, the button may be labeled "Hold toStart," "Start" or "Push to Start." Check that the dryer's settings knob is set to an actual drying mode and notsimply "Air" or "Tumble." On most Whirlpool models, themanufacturer states that the settings knob should be set to"Accudry," "Timed Dry" or "Automatic Dry." Clean the lint trap, typically located at the top of the dryer and removedby pulling its plastic handle. Over time, lint and dust builds up here. Thethicker the trapped layer of lint, the slower your dryer performance. Whirlpoolrecommends removing built up lint after every dryer load. Remove some of the wet clothes inside the dryer if it's taking an unusuallylong time to dry your clothes. Whirlpool warns that placing too much clothinginside the dryer reduces hot air circulation, which also reduces dryingcapabilities. Recommended dryer load s vary, with compact Whirlpool modelsholding approximately 3.4 cubic feet while extra large Whirlpool dryers holdingmore than 7 cubic feet.
4answers
Whirlpool dryer
is hte light going out?? ope nteh door and try physically pushing the door switch (grey rectangle in the top center of door opning, does it "click" as you push it??? if not really push it, pull it, samck it a fewt imes. sometomes i find they hang up and dont function properly. but when i go to replace one it pops out as i start to change it
Need help
This is some basic info I could find on your dryer. I will need you Serial Number in order to determine the year it was produced. Please post back with comments and let me know.
Whirlpool Duet GEW9250P 7.0 Cu. Ft. Super Capacity 8 Cycle Front Load Electric Dryer With AccuDry Sensing System. Dry clothes in the time it takes to wash them. The dryers uses AccelerCare™ technology to work just as fast as the washer (Up to a 9 lb. load), giving you more time to enjoy all the good things you've worked hard to achieve.
AccuDry™ Sensing System - Monitor remaining moisture and automatically stop the cycle when the load is dry, with the AccuDry™ sensor. Reduce overdrying and save time and effort, by not having to return to the dryer to re-check progress.
Senseon™ Drying System - Moisture-sensing strips and temperature sensors inside the dryer drum monitor how fast the load is drying, how hot the air should be and when clothes are dry. The system automatically stops the cycle to help save time and prevent overdrying. Senseon™ technology safely dries clothes faster than it takes to wash them.
Wrinkle Shield™ Plus Feature (120 Minutes) - The Wrinkle Shield™ Plus option automatically tumbles the load without heat to help prevent wrinkles from forming.
Whirlpool brand offers an ergonomic solution for its front-load washers and dryers to help reduce bending, stooping, or arching. Based on your height and laundry room needs, optional 10 in. and 15.5 in. pedestals make loading, unloading, and filling the dispensers easier. The 15.5 in. pedestal doubles as a storage drawer with a convenient sliding shelf to support your laundry basket.
Item Features:
  • Super Capacity Plus - 7.0 Cu. Ft.
  • AccuDry™ Sensor
  • Senseon™ Drying System
  • 8 Automatic Cycles
  • Bulky Items Cycle
  • Adjustable End-of-Cycle Signal
  • Wrinkle Shield™ Plus Feature (120 Min.)
  • 5 Temperature Selections
  • Quiet Dry Plus Noise Reduction
  • Dry Rack
  • Reversible Side-Swing Door
  • Dryer Door Window
  • Reversible Side Swing Door
  • Electronic Controls
  • Front-Mounted Lint Screen
  • Interior Drum Light
  • 4-Way Venting
  • Porcelain SpillGuard™ Top
  • Optional Storage Pedestals Available
  • Stackable Installation with Matching Washer
  • Matches Duet® Washer
Specs:
  • Warranty: 1 Year Parts & Labor
  • Capacity: 7.0 Cu. Ft.
  • Dimensions (HxWxD): 38 in. x 27 in. x 31 1/2 in; Depth with Door Open - 51.5"
  • Construction: Front Access, Reversible Side-Swing Door Style, Powder Coat Drum Material, Dry Rack, Extra Large Front Mount Lint Screen, Power Cord & Venting Accessories, Stackable
  • Controls: Electronic Controls
  • Electrical Requirements: 30 Ampere, 120/240 Volts, 60 Hertz (1/second). AC-ONLY. USE COPPER WIRE ONLY. A FOUR-WIRE OR THREE-WIRE, SINGLE PHASE ELECTRICAL SUPPLY REQUIRED. A TIME-DELAY FUSE OR CIRCUIT BREAKER AND SEPARATE CIRCUIT IS RECOMMENDED.
You can get an owner's manual replacement for your dryer at laundrymanuals.com. I believe there is a membership fee for the website, however. I hope this info helps you.
Have to dry close twice on automatic, or once on timed. Random triple beeps.
Sounds like the drum belt has broken. It's connected around the drum and motor pulley. Without the belt turning the drum it will be near to impossible to dry the clothes, Hope this helps, Sea Breeze
Top Whirlpool Dryers Experts
Virgil Watts
Paul Bade
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
