Hi Rita van Kraayenburg, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? MAKE MODEL AND OPERATING SYSTEM?Hi Rita van Kraayenburg, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? MAKE MODEL AND OPERATING SYSTEM?
You can't post conmments that contain an email address.
Remove the 3 Phillips screws that secure the keyboard to the computer.
Turn the computer right-side up, and then open the display as far as possible.
Turn the computer upside down, and locate the keyboard release access on the bottom of the computer, inside the battery bay.
Insert a flexible tool into the opening, and then press inward to release the keyboard.
Turn the computer right-side up, and then lift up on the top and left edges (1) of the keyboard until the keyboard releases completely. Component replacement procedures 416. Slide the keyboard back until its top edge rests on the display assembly . Release the zero insertion force connector to which the keyboard cable is attached. Disconnect the cable and then remove the keyboard.
<p>If a loose screen hinge screws <br />
<p>1. Turn off your computer and remove all components of the
computer that sending an electrical current to the system, including power
cables, peripherals and battery. <br />
<p><br />
<p>2. Close the display and turn off the computer base to cope
with the hinge side of the computer to you. <br />
<p><br />
<p>3. Extract the four screws on the bottom border. <br />
<p><br />
<p>4. Remove the rubber plugs on the back of the hinges of the
screen and the two screws underneath them. <br />
<p><br />
<p>5. Turn off the computer and open the screen, so they sit
flat against your work. <br />
<p><br />
<p>6. Press the area marked on the right side of the keyboard
cover (the plastic strip on the top of the keyboard) to it from the computer.
Lift your right a little push and cover the central part of the keyboard to
release it. Lift up the middle and let the left up to the keyboard cover for
free from the computer. <br />
<p><br />
<p>7. Unzip, the four screws on the top of the keyboard and the
keyboard on the fold of the palm rest with the buttons down. Disconnect the
keyboard cable and remove the keyboard. <br />
<p><br />
<p>8. Loosen the two screws that secure each display hinge to
<p><br />
<p>9. Attach the keyboard and the keyboard. Make sure all
screws that secure each part to fix. <br />
<p><br />
<p>10. Place the screws on the back of the hinges of the screen
and replace the rubber stopper. <br />
<p><br />
<p>11. Insert the battery, cables and components that you
removed in step 1 to complete the process. <br />
<p><br />
<p>Broken so replace hinges <br />
<p>1. Turn off the computer and get rid of its power
transmission components. <br />
<p><br />
<p>2. Turn off your computer and remove the four screws on the
hinge side of the base of the keyboard. <br />
<p><br />
<p>3. Remove the rubber plugs on the back of each screen hinge,
and pull the two screws in the hinges. <br />
<p><br />
<p>4. Unplug the computer and open the screen. Follow the
instructions to step 6 of chapter 1 to the keyboard cover. <br />
<p><br />
<p>5. Remove the keyboard by following step 7 of Section 1 <br />
<p><br />
<p>6. Disconnect the cable from the connector on the computer
screen right in the middle of the screen panel. <br />
<p><br />
<p>7. Disconnect and remove the two antenna cables from the
mini-PCI wireless card in the middle left of the keyboard and cables in the
guide, take it to the computer. <br />
<p><br />
<p>8. Unzip the two screws on each hinge and lift the computer
screen. <br />
<p><br />
<p>9. Remove the six rubber pads on the front panel display,
and remove the screws under them. <br />
<p><br />
<p>10. Remove the display. <br />
<p><br />
<p>11. Unzip the two screws on each screen, internal hinges and
remove the hinges of the screen. <br />
<p><br />
<p>12. Follow the procedure in reverse, with hinges to the new
computer installation. Make sure you remove all the screws, so everything is
nice and tight as the computer is assembled. <br />
Hello. There are several things you can try to unlock the keyboard. - Shutdown the computer, then turn it on afterwards. Check keyboard functionality. - If you're using a desktop, disconnect keyboard, restart computer then plug the keyboard back once the computer has boot up completely. - If you're using a laptop, turn it off, unplug the power cord, remove the battery, re- seat the battery after a minute, plug-in the power cord then turn on the laptop. - Disable On-Screen keyboard - Right click "My Computer" icon on the desktop then select "Properties". Click "Device Manager". Look for the Keyboard, hit the drop down arrow beside it to display the installed keyboard. Right click on it and if you see "Enable", click on it, otherwise it's already enabled.
Hi, connect your tv to your netbook, once connected, hold down FN (bottom left of your keyboard) then press accquired F button (top of keyboard). Ie on my laptop its FN and F5 together. This will turn your laptop screen off while you watch Netflix on your tv. To turn screen back on once finished, repeat the process. Hope this helps and please rate,, thanks
You can manually test which mode the keyboard is set to and change its configuration by following the steps below.
Open a word processing program and type the word jump on the notebook's keyboard.
If the word displays as jump , then the keyboard is set to its default mode. If the word displays as 140* , then the keyboard has been set to a number pad configuration.
To switch modes, press Fn + Num Lock . (Fn key is next to Ctrl key on the left)
Type jump again to confirm that the keyboard configuration has been reset.
The keyboard's configuration has been successfully reset.
Hi, Turn the computer off and close the computer lid. Remove the battery and the AC power supply.
1st we need to remove the switch cover or keyboard bezel. This is plastic strip that runs above the keyboard.
Turn the computer upside down with the front panel towards you. Remove the three Phillips screws that secure the switch cover to the computer.
Turn the computer display-side up with the front toward you. Open the computer as far as possible. Lift the rear edge of the switch cover and swing it forward until it rests on the keyboard.
Release the zero insertion force (ZIF) connector to which the LED board cable is connected and disconnect the cable from the LED board. Remove the switch cover.
Now remove the panel directly above the battery compartment and remove the 2 keyboard screws there and another 2 screw in the battery compartment (they should me marked with icons of keyboards)
Turn the computer display-side up with the front panel towards you. Open the computer as far as possible. Lift the rear edge of the keyboard until it rests at an angle. Slide the keyboard back to disengage the tabs on the front edge of the keyboard from the top cover. Swing the keyboard forward until it rests on the palm rest.
Release the ZIF connector to which the keyboard cable is connected and disconnect the keyboard cable from the system board.
Remove the keyboard.
Just reverse the procedures to replace everything.
