This is one link that shows how in pdf (however if you provide your exact model and operating system, you can get a clearer answer) https://www.lenovo.com/shop/americas/content/user_guides/a720_ug_en.pdf
touch screen starts on page 12
2.1 Touch Screen Calibration Prior to first use or whenever the touch screen reacts in a different place where you are touching it, start the calibration program. The procedure is as follows: 1. In Windows 7, Select "Start" - "Control Panel". 2. In Control Panel, select "Hardware and Sound". 3. In "Hardware and Sound" window, select "Tablet PC Settings". 4. In "Tablet PC Settings" dialogue, click "Calibrate" button. 2.2 User Gesture Instructions for the Touch screen The Touch screen supports single touch and rotational movements, enlargement and reduction multi-touch operations, and the user can transmit position information to the computer via touch. The touch screen uses a very low pressure movement recognition method, which only needs the finger to move lightly on the computer display screen or make a simple hand gesture to be detected by the main computer processor.
Does it work when you plug in the charging cord? if, so you may have a battery problem. Try removing the battery and reinstalling it. If it doesn't work with the charging cord you should contact Lenovo tech support on the Lenovo website for assistance in returning the laptop for repair.
I was having the same problem in lenovo s10 3s , but I took it to service station and found that the internal cable which connects the screen to base was loose. You too take it to service station because no power issues and os problem is to do with screen flikr.
