I cannot install to my computer with Vista 64 bits
The problem cannot be solved. You need to give more information.
Firstly, do you have a 64bit PC? If so then is the Vista disc you have, an upgrade disc or an OEM straight install disc which requires no OS on your PC to install Vista 64? If it is an upgrade disc, then you need a qualifying OS, on your PC to upgrade it to Vista, for eg. WinXP, Win 2000, etc. If it is an OEM Disc then maybe the PC cannot find the disc to boot from when you switch on your PC. Get into the PC's System Bios and set the boot order so that the CD/DVD disc drive is scanned first rather than the Hard Disk drive of your PC at switch on. Then save the settings and exit the system Bios. To get into the system Bios you need to either press the 'Del' key or the 'F2' key when the PC is switched on.
