To use the radio function on your Nelsonic Clock Radio model NLC 608A, please follow these steps:
Make sure the clock radio is plugged into an electrical outlet and turned on.
Press the "Radio" button to turn on the radio function. The display should show the current radio frequency.
Use the "Tune +" and "Tune -" buttons to tune to the desired radio station. You can also hold down these buttons to automatically scan through the available stations.
Adjust the volume using the "Volume +" and "Volume -" buttons.
To switch between AM and FM radio, press the "Band" button.
If you want to save a radio station as a preset, tune to the desired station and then press and hold one of the numbered preset buttons (1-10) until you hear a beep. You can then access the saved station by pressing the corresponding preset button.
To turn off the radio, press the "Radio" button again or simply turn off the clock radio.
Depends on the car radio you have. On some models you tune the station that you want, then press and hold the button that you want to save the station to for about five seconds. The display will usually blink once when the station is saved.
Your radio might save the bass & treble settings with each station. Try choosing a station, set the bass, treble and any other variables (mid-range, etc.) and then SAVE the station to a button. Do this for all of the buttons / stations you like.
If this doesn't solve the problem, tell us about the radio (AM/FM/Cassette/CD and Factory or aftermarket - in which case we'll need to know the make and model of the radio.
If radio has save button then tune your station push save button then push a number on preset you want it saved to. The radio automatticlly stores the strongest station in your area.
To program your radio stations to the memory buttons; Tune to the station that you want to save, then press the memory button (located next to the FM mode button on the lower right side of Tuner) then press the number button that you want associated with that station. You may save up to 24 stations. If you want to save a station in memory 10, tune in station, press the Memory button, then press 1 followed by 0. you must press them within a couple seconds of each other, or the first number pressed will be the memory button that saves. You may save FM stations and then Save AM stations. But you will overwrite any previous station saved to a given number when using that number again. If you save an FM station on a number, then save an AM station on another number, when you press the preset number, the tuner will automatically switch radio bands to accommodate the stations given band. cool.
Hold down the one of the numbered buttons (1-6 I think) at the bottom for 3-5 seconds while listening to the radio station you want to save. You should hear a beep, and the station will be saved.
this is how i preset my stations, im not sure if you have done this before.
fm can save 20 stations and am can save 12
1] chose your desired station
2] press & hold the play/memory button until P01 pops up and flashes
3] to save the station, press & hold the play/memory button
if you'd like to save another station, then repeat steps 1 & 2,
then press the play/memory button again until P02 pops up,
repeat step 3.
to listen to your preset station, all you have to do is press the play/memory button.
try this on most units search the station that you want to save and when its on it press and hold the numbered buttons till it says on the display saved or you hear a tone
Just bought the same unit but the instruction manual was double dutch. After messing around for a while I managed to do it like this. Whe the unit is set to DAB, Press the Sel+/TU+ or the Sel-/TU- button on the unit (not the remote) until the DAB station displays and then press the Select CH+ button again on the unit. Wait a few seconds while the word "tuning" is displayed and that station should now play. To save the station as a preset do this. When the station is playing use the remote and press the PRG/MEM button once. Then press the number for which preset you want that station to be. The station will be saved. EG to save Radio 1 as Preset station 1, play Radio 1, Press PRG/MEM, then press number 1. After that whenever you press number 1 on the remote Radio 1 will play. Do the same with any other station you wish to save. To save station 10 press the 0/10 button on the remote. To save station 11 press 10+ then 1, 12 is 10+ the 2 etc. Good luck Dopeyemma
