Cars & Trucks Logo
Nick Corzilius Posted on Apr 24, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When i change stations on my radio it changes all the settings on bass and tremble on my 2007 grand prix?
Steve
Level 3:
  • Cars & Trucks Master 3,290 Answers
  • Posted on Apr 24, 2015
Steve
Level 3:
Answers
3290
Questions
Helped
1128186
Points
12184
Hi Nick,
Your radio might save the bass & treble settings with each station. Try choosing a station, set the bass, treble and any other variables (mid-range, etc.) and then SAVE the station to a button. Do this for all of the buttons / stations you like.
If this doesn't solve the problem, tell us about the radio (AM/FM/Cassette/CD and Factory or aftermarket - in which case we'll need to know the make and model of the radio.
I just bought a 2006 grand prix and yesturday the radio lights and buttons dont work. The cd wont eject bc buttons dont work and the lights on the radio dont work either u cant see the time ornothing. U...
Hmm sounds like could be that the car was hot jumped from a dead battery or was jumping another car and it may fried the stereo. Should be able get a factory replacement out a junk yard less than $50
2007 Pontiac Grand Prix heater dosent work
blend door actuator stuck on cold setting .... make sure ur not low on coolant to cause that will always mean no heat
Can I change the battery in my pontiac grand prix gxp without going to the dealer
of course you can but make sure you have the radio code written on the back of the sun visor before you start
2002 Pontiac Grand Prix - multi-fuse related problems.The A/C keeps shorting out and the garage replaces the fuse. Where is the fuse box for the A/C located? Also, the radio display is dim/non existent...
I can't answer because I have other question open, sorry, but here I send any comments and clues to solve (I hope).
For the FUSE PANEL, location and description, I suggest check the 2000-Pontiac-Grand-Prix-Owners-Manual (page 330 and next). A/C have one "diode". Check it.
About your radio display, sound like a internal problem, keep in mind that the CD is working.
The Security Litgh, its possible that you have any problem with the THEFT system or any aftermark alarm (if you have).
Resetting Oil Service Indicator Lights - Pontiac Grand Prix, 1999-03
Driver Information Center If Equipped). Turn the ignition to ON without starting the engine. Fully press and release the accelerator pedal three times within five seconds. If the CHANGE OIL Soon indicator flashes two times, the system is resetting. Turn the ignition key to OFF, then start the vehicle.
If the CHANGE OIL SOON indicator comes on and stays on, repeat the procedure. To reset the OIL LIFE indictor if equipped with a Trip Computer: Press the trip MODE button until the light appears next to OIL LIFE. Press and hold the trip RESET button until the oil life percentage changes to be 99 percent.
Hope helps (remember rated this).
1helpful
2answers
Changing serpentine belt 3.8 2007 pontiac grand
  • Make sure your new belt exactly matches the old belt demensions
  • Take a breaker bar or big rachet & release the tension on the automatic tensioner; very slowly
  • Loop the old belt around the pulleys & fan
  • Install new
2answers
07 Grand Prix Trans. Fluid Change Schedule
you may change the filter and fluid, but in most cases it will not do any good. Find a good trans shop to check it out.
1helpful
All speakers in 05 Grand Prix GTP, have not any bass. All treble. Any suggestions for this? None of the fuses are broken under the hood or in the fuse holder inside the car. The settings on the stereo are...
Most radios on these are software driven This may be a software update problem. You will probably have to go to a dealer to see if there is an update they can download to your radio.
3helpful
Aux input location
Though I'm sure there is an AUX button on the radio, there isn't actually an auxillary port on a 2007 Grand Prix stock radio.I'm sorry to say, but you would have to get an aftermarket radio.
7helpful
Can't see anything on the clock/Radio Display
the radio display is lighted by a tiny bulb inside the radio, to change this u must remove the radio from the dash and take off the top sheet metal cover, under that u will see a small twist in bulb socket, replace that little bulb, the bulb is about $2 and avail at any full sevice auto parts store.
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
