I see HDMI and the green audio outputs, but not the red and white RCA jacks. Please help.
I assume the Panasonic is a TV. I have never heard of green audio outputs. Audio outputs should be red and white (for RCA plugs). There are adapters available that convert the yellow, red and white component outputs to HDMI. You can get them at GameStop (I bought one recently to connect a game system for my daughter). If you have a TV converter box from your cable or satellite provider you might be able to connect the audio out on the cable box to your Technics receiver and run a HDMI to the TV (be sure to turn off the TV's internal speakers through the TV's menu) for video.
SOURCE: How to set tuner presets in Technics SA-GX550 receiver
The user manual is available free at:
http://support.panasonic.co.nz/docstore/SAGX550%20Book.pdf
SOURCE: sa-dx1040 dvd optical input works, tv and cd do not.
You have to manually select digital input on the receiver.
SOURCE: Max. wattage for speakers w/ Technics Receiver SA-GX100?
I too have a Technics SA-GX100 and it's rated at 2 x 40W @ 8 Ohms. I have the Technics SB-2840 floor model speakers hooked to it, which are rated at 200W Music Input - 8 ohms. It sounds very nice just to be a 40W receiver.
SOURCE: digital optical output for technics 5.1 surround sound receiver
I went to the HDTV plasma manual. It stated the only way the digital optical audio output would work (from this TV) was to go to the menu, select audio and turn off the TV speakers. Basically, it had nothing to do with the technics receiver.
Testimonial: "worked like a champ!"
