First restart the laptop,if this step does not work,take out the battery plug the adaptor and start it if the second does not work the start usualy and connect external monitor to the laptop if works then your sceen is demaged.
These also have an overheating chipset problem. If you try all that Florin has suggested I would expect it to be the board.
Sorry. Pressed 'enter' too quick. These can be repaired with a system called 'reballing' where the chip is removed and resoldered with a superior solder. These do not work, sometimes, for long so I would look for a board or the same model with a broken screen or such fault where the board is said to be working. You can always get a refund via EBay if it doesn't. I wish you the very best of luck. Ray
SOURCE: my dell studio 1735 will not turn on
You mean you have no display in your monitor?If it is the problem. Then your computer has something wrong with it. Did it beep several times while you turn your computer on?There are different types of beeps and it gives different meanings. I suggest it is better to take your computer into a service center and have it check by a qualified technician. Comments please for further assistance. Thank you..:-)
