Two fan blades are loose and hanging lower than the others. I need to take them off to see if they are broken or have come loose from connectors..
SOURCE: I have a harbor breeze baja fan and one of the
replacement blades are available at home depot and lowes. If you don't see them, ask in the fan department
SOURCE: Remote fans quit working during a thunderstorm-lots of lightning
I've been having the same problem with my remote not working. I actually just checked the dipswitches in the remote against the ones in the ceiling fan, and they somehow were not the same. It seems that the 4th dipswitch may have inadvertently been altered due to the battery either being changed or just moving. I advise you all check out the settings on the actual fan to see whether or not they match up.
Twist the cap covering the wiring above the fan (make sure the power is off, just in case), and you will see a black box like thing straddled towards the top. There is a little rubber square cap guarding the dipswitches. Take that off and note the setting of the 4 switches (on/off). Compare it with the remote by taking the batter pack off and looking at the 4 switches there.
I noticed that the 4th switch on my remote was turned on when it should have been off. I changed it back, and now it works.
Hopefully this helps you all.
SOURCE: looking for a replacement globr for a Harbor
you can write to the company and they will more then likely have a replacement one for you
SOURCE: I need to find a light kit for a harbor breeze
You should be able to pick these up at Lowes if I'm not mistaken. I just bought a Harbor Breeze ceiling fan from there and saw the light kits around the same area. I also believe that, you dont necessarily have to get a Harbor Breeze light kit and that some are interchangeable.Hope this helps some.
SOURCE: Harbor Breeze Ceiling Fan remote does not work
just replace bettery of your remote and check it again
