No, universal ceiling fan light kits don't work with every single fan. You'll have to check the details of the kit before purchasing, to ensure that your fan is compatible. Also, it's important to note whether your fan is light kit adaptable. This means when it was manufactured, did the manufacturer design the fan to be able to connect/install a light kit later or not. In many cases, if the fan didn't come with any lights, it may not be light kit adaptable.
No, Harbor Breeze light kits do not work with every fan. You should check the description first or ceiling fan manuals first for more details.
You can also contact Litex Industries for more details.
For information on Harbor Breeze light kits you will need to check the model number and consult the manual. Do you know the model name and number? If you do you can check for the manual here on Harbor Breeze Ceiling Fan Manuals
I found the articles on Harbor Breeze Accessories helpful for solving remote control problems.
There is also a great deal of information on Harbor Breeze helpful for solving remote control problems and many other issues involving your Harbor Breeze Ceiling Fan.
Hope this all helps
SOURCE: I cut the plastic wiring connector, fan motor to
The top wires, black, white, and green are the ones to hook to just run the fan. The blue wire is wired with the black at the top if you want the lights to work. At the light kit, the blue and white wires power the lights.
SOURCE: I need to find a light kit for a harbor breeze
You should be able to pick these up at Lowes if I'm not mistaken. I just bought a Harbor Breeze ceiling fan from there and saw the light kits around the same area. I also believe that, you dont necessarily have to get a Harbor Breeze light kit and that some are interchangeable.Hope this helps some.
SOURCE: my universal harbor breeze remote
Hello ROLYATI At the fixture/motor itself is a switch to change rotation.Look for a small black button.
