Have replaced the eyebrow board and the thermistor with a snip the tip adjustable thermistor.
These dual service refrigerators are somewhat tricky. Did you check the gas system for any carbon buildup around the flame/burner area. If the flame is not the proper size it will not get cold enough to shut off. Clean all carbon/dirt from the flame area and check again. Propane causes deposits after a while.
SOURCE: RM2652 fridge works on 110 and gas but won't switch between them
Remove the upper control board panel. Use a small screw driver, open the freezer door, under the control panel you will see a slot on each side. Put the screw driver in the slot and push up. That side of the panel will pull out. Do the same on the other side. Turn the control panel over and unplug the circuit board and wait 15 seconds. Plug the board back in and give that a try. If that does not work replace the upper board. To order a board you will need Model, Serial and product # found on the inside of the fridge.
Thanks for using Fixya
Jerry
SOURCE: Is there a 12volt coil in a Dometic rm52 refrigator
What you would need to do is get an inverter to power the icebox. Turn the 12 volts into 110 to power up the compressor. THE INVERTER STORE has aone for $199
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: My unit works great on AC (cools to 30degree), but
Your fridge has two manual settings to adjust it's internal temperature. Obviously, it most likely has a standard control (1-5 or 1-9 depending on the fridge) that you can adjust on the control panel. Some fridges are preset (no control panel adjustment) and must be adjusted on the inside of the unit. If open your fridge, look at your cooling fins. You will notice a metal slider on a wire attached to one of the fins. Moving this sensor up or down along this fin will set the internal temperature of the fridge. You will have to play with it a bit to get it set properly (with a thermometer), but you should be able to get it to the proper temperature. I hope this solves your problem. Thanks... John Charles
SOURCE: I have a Americana RM2652 It works on gas, but not
My guess is that the element is shorted out not much else to go wrong, elements are not that resilient to shocks and bumps.
