If its running Windows 8 the login might be linked to a microsoft account. from another computer login or reset your password to that account and try logging back into the laptop (as long as it has an active internet connection) If its windows 7 or older you might need to find a Live repair disk (ERD or Hiron's boot cd or something along those lines that has a password recovery tool incorperated)
Worst case you would need the windows installation disk or restore disks that came with the laptop
SOURCE: reset factory password on t61 lenovo
Pulling the bios battery does not work on the Lenovos - youll be wasting your time. Where did you get that information Jadestar - Ill bet you can't name one person for whom your solution works on these laptops!!???
SOURCE: My Lenovo y510 display is blurry. Sometimes it
Need a replacement soon.
If you want a temporary solution for your eyes, use a regular monitor, and plug it to the laptop
Don't forget to rate if this answer helps
SOURCE: can't find drivers for win 7 64-bit for lenovo y510
Windows 7 is a new platform and every hardware manufacture is developing the driver suits for it.Meanwhile you will have to download the drivers directly from the chip manufacturers site e.g. for sound you can download it from http://www.realtek.com.tw/downloads/.
About the chip manufacturers you can know from the Y510 page where the drivers are there for Vista or XP.
Thanks.
SOURCE: how to remove bios password in lenovo 3000 y510
This information is intended for experienced users. It is not intended for basic users, hackers, or computer thieves. Please do not try any of following procedures if you are not familiar with computer hardware. I'll not be responsible for the use or misuse of this information, including personal injury, loss of data or hardware damage. So use it at your own risk.
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
SOURCE: password bios lenovo y510
To reset the BIOS password read the information from this link.
In case of your Lenovo laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper and I wouldn't recommend doing it especially if it's under warranty.
