MY SON WANTS TO PLAY MIECRAFT AND HAVE PURCGASED DOWNLOAD AND NOW CANT PLAY AS NEED UP TO DATE GRAPHICS CARD?
SOURCE: video graphics card
being a PCI card, not a AGP or PCI-E the system may not simply switch to that one a primary display adapter when you install it, in the bios under advanced system settings or intergrated periferals, you should have an option to change the primary display adapter, make sure a PCI adapter is included.. if it isnt, chage it to recognise a PCI card as a primary adapter, turn the system off, and install your card then, depending on the bios/model of the mainboard on some of those dells, it may be a little hard to find, ive had to play with a few of them
SOURCE: upgrading graphics card
Connect the monitor to the onboard video connector first. then
you need to disable the on-board graphics in the BIOS save the setting and shutdown. Then connect the monitor to the GeForce video connector and boot up then you will get a video signal on the GeForce video card.
SOURCE: Graphics Card Upgrade for HP Pavillion a6600f
if your video slot is a agp try buy a nvidia geforce 7800gs used on ebay cheap and good ;p if u have a pci-x slot u can have a better card also check your power suppy if is enough for it you can ask to a reseller near you cya
SOURCE: Upgrading my Acer Aspire M1641 Desktop graphics card
The motherboard will support any PCI Express x16 or PCI Express 2.0 x16 video cards. Your main concern should be with the power supply since it is either a 300w or 250w.
Here is a pretty good choice for your price range:
http://usa.asus.com/products.aspx?l1=2&l2=8&l3=725&l4=0&model=2328&modelmenu=1
Input your info here to see if you need a power supply upgrade.
http://support.asus.com/PowerSupplyCalculator/PSCalculator.aspx?SLanguage=en-us
A little money for system memory would be good if you have less than 1 Gig.
You can test it here:
http://www.crucial.com/systemscanner/index.aspx
If you are saving money by not buying a motherboard and want to spend it (which is what I would do), I would put the money into a the video card and power supply.
Like this:
http://usa.asus.com/products.aspx?l1=2&l2=8&l3=726&l4=0&model=2705&modelmenu=1
And this:
http://www.amazon.co.uk/Netzteil-Corsair-620W-ATX-2-2/dp/B000KJNK8U/ref=sr_1_10?ie=UTF8&s=electronics&qid=1248740669&sr=1-10
I do not know the dimensions of the Aspire Case, so one thing to keep in mind is the dimensions of the card and the power supply. Make sure they will fit before buying.
If you start replacing motherboards and such, you might as well just go with a whole new system. A new motherboard, new CPU, new memory, new graphics, new power supply, fast hard drives, new case.
SOURCE: what is directX9 capable graphics card
Microsoft DirectX is a collection of application programming interfaces (APIs) for handling tasks related to multimedia, especially game programming and video, on Microsoft platforms. Originally, the names of these APIs all began with Direct, such as Direct3D, DirectDraw, DirectMusic, DirectPlay, DirectSound, and so forth. The name DirectX
was coined as shorthand term for all of these APIs (the X standing in
for the particular API names) and soon became the name of the
collection. Direct3D (the 3D graphics API within DirectX) is widely used in the development of video games for Microsoft Windows, Microsoft Xbox, and Microsoft Xbox 360.
Direct3D is also used by other software applications for visualization
and graphics tasks such as CAD/CAM engineering. As Direct3D is the most
widely publicized component of DirectX, it is common to see the names
"DirectX" and "Direct3D" used interchangeably.
The DirectX software development kit (SDK) consists of runtime libraries in redistributable binary form, along with accompanying documentation and headers for use in coding.
The latest versions of Direct3D, namely, Direct3D 10 and Direct3D 9Ex, are only officially available for Windows Vista and Windows 7, because each of these new versions was built to depend upon the new Windows Display Driver Model
that was introduced for Windows Vista. The new Vista/WDDM graphics
architecture includes a new video memory manager that supports
virtualizing graphics hardware to multiple applications and services
such as the Desktop Window Manager...............sodeep
Can you give me the model number of your desktop PC so I can determine what card(s) may work and whether the PC is capable of supporting the software?
