To Adjust the Thermostat
Pull the OVEN TEMP knob off the shaft.
look at the back of the knob and note the current setting before making any
adjustment. The knob is factory
set wit the knob directly under the pointer.
1. Pull of the OVEN TEMP
knob
2. Loosen both screws
on back of the knob
3. Adjust lower screw
so it moves in the desired direction.
You will hear and feel the notches as you turn the knob. Each notch changes the temperature about 10 degrees F.
4. Tighten the screws.
5. Return the OVEN
TEMP knob to the oven.
Re-check oven performance and make the
necessary adjustments accordingly.
