Not sure what you mean - if you wish to produce images taking up less storage, then reduce the resolution; if you wish to reduce the size of printed images, use image-editing software on your computer.
Have you tried checking on the page, that when you select print, it shows how many pages you want, portrait or landscape, on this page it should also have the proper ratio to print, ie.,100% vs.say 75%. Check to see if it's still at 100%, it's possible that it reduced size to fit a page and didn't change back
It happens when the documents is on A4 size and the printer is set to print on letter size (which is smaller in size). Hence the printer automatically resizes the prints which result in larger margins and print as compared to the actual document. Therefore, when you print the documents (Press Ctrl+P) you have to select the paper (A4) from the print properties.
it's printer and computer, you need to find out what is real reason is?
first, check on your printer, is there any button has set enlarege/reduce size button? and then go on computer, check the printer property, is there any setting given to reduce print size or what do u want to print out? before you print it out you should check that by print preview option and then if you not satishfy with it you should try to increase size of every fonts.
press enlarge/reduce button on front panel,
press the right or left direction button on the OK pad, until Zoom appears, press the down button, set the factor by presssing the up and down direction button, press OK to set.
To copy press Start (Black/Color) on front panel.
Same process to reset to the magnification.
try using a ruler to check if you have the correct paper size.
open up HP Solution Center verify the printer settings..
use borderless printing, paper size 4 x 6.
