I need and unlock code for this phone i have imei and serial number to it the phone was refurbished
You can get the Network unlock code for your Samsung Galaxy S3 phone from TheUnlockSpot.com and unlock your phone from Network lock easily.
SOURCE: i need the network unlock code for samsung SGH -E390
To unlock your samsung mobile,follows these steps
Do a custom reset:
*2767*2878# once this has finished rebooting turn the phone off.
Next
a SIM card from a different service provider needs to be pushed half in
- (Push it fully in then slide it back out by about 1/2 a centimeter),
Turn on the phone - you will now see an "Insert SIM" message,
Now perform a full reset:
*2767*3855#
When the phone powers off, quickly push the SIM card fully in, and let
the phone power back up.
After you do the reset, check and make sure that your Network lock is active by pressing *#7465625#
If it isn't active you must use this code to reactivate it:
*7465625*638*00000000*00000000#
Then you have to deactivate the SP lock first. To do that you need to input:
*7465625*77*00000000*00000000# (this will reset the lock)
Then you enter:
#7465625*77*00000000# (to disable the SP lock).
Then you disable the Network lock:
#7465625*638*00000000#
The phone is finally unlocked.
SOURCE: i need SIM network unlock
Hi am having problem with my Samsung galaxy TEOS I5800IME 352286/04/336876/9 asking for SIM Network unlock PIN. Can you help me please
SOURCE: how do i get a free sim network unlock pin for att
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
SOURCE: need my samsung galaxy s GT-i9000 unlock code
dial this *7465625*638*# then type the MNC/NCC code of the carrier want to for your phone .. next type this on the second box 00000000
