P-07-FAULT IN CHARGING, WHAT IS THE PROBLEM
SOURCE: I have a kipor ig6000 generator.When i connect my
Your generator is running a bit too fast, and the frequency is greater than 60Hz. Most generators are setup for 62-63Hz no load. You can adjust this at the governor for the engine.
Another possibility is that the alternator is providing electric with a large amount of harmonic distortion, which some appliances don't tolerate well (dirty power). Try adding a noise filter between the generator and espresso maker and see if that helps. The espresso maker may also expect to be grounded, which the generator is not able to provide (unless you are driving a ground rod). The noise filter may also require a ground as well.
SOURCE: My "KDE19STA3" Kipor generator keeps showing fault "L&H Freq.
this is telling you that the power frequency is above or below the safe limit and so shuts down.
do not run a load but
press the function button and hold then switch on but dont start keep holding until ph2 or similar is displayed then start read the frequency and adjust the engine speed until it reads correct then try will full load and adjust accordingly 1 or 2 hz either way will be ok
