Warning light on Kipor KDE 25 SS is on?
SOURCE: run flat tyre warning light is on i have checked tyre pressure
This will only come on when a tyre has dropped in pressure (not spare). It work on the principle that a tyre with less air has a smaller rolling circumference and therefore a different wheel speed. This is then monitored against other signals from other wheels and determined that a loss in pressure has occured.
If all tyre pressures seem ok, there could be a chance of a small unoticeable leak and would require a bath test. This is when the tyre is dipped in water and bubbles would appear where the puncture is.
Ultimately the system may just need to be reset, or has incorrectly been reset from a tyre change. For this you just press and hold the TPC button (located on the centre console above the gearstick - looks like a flat tyre with an exclamation) turn on the ignition to position 2 and the light will come on re then yellow,go out, come back on yellow. When it comes back on yellow it re-initializing the system. You can let go of the button and after 20 odd seconds the light will go out for the final time, completing the reset.
If the light continues to come on after the reset then you definitely have a puncture somewhere!
Hope this helps!
SOURCE: Citroen C5 airbag fault warning stays on
I had this problem after the dealer serviced the car! They couldn't fix it despite several tries so I was stuck with the fault. Then I remembered I had the same fault in my previous XM model but it would reset on engine re-start. On that car it usually happened after a full left or right steering lock combined with hard braking when maneuvering in tight car parks. I figured that if this caused the problem then maybe it could also cure it. I tried it in a safe place, alternating left and right lock with abrupt braking. It didn't seem to clear the fault but after a 15 minute trip to the shopping centre I was surprised to find that the fault was gone when I re-started the engine! I have not had this problem in over a year now despite living with it for over three weeks at the time.
SOURCE: need to reset to run flat tyre warning light on
i have a bmw , 1 series, i have just put air in my tyres and there is now a warning light on the dashboard, have i over inflated my tyres?
SOURCE: Ford Mondeo Mk3 Estate 2L. Air bag / seat belt Warning Light
Common fault on FORD
Usually due to a poor connection in the YELLOW PLASTIC CONNECTOR underneath the passenger seat.
Just push it together properly and it should clear the AirBag fault
SOURCE: KIPOR KDE 6700TA 5KVA Generator
forget about the display read the manual and find out how many volts are needed to charge the battery....then
get a voltometer and disconnect the terminals from the battery and connect them to the voltometer while the generator is running...
find out what the reading is...if the reading is zero (0)...then post a problem on (no out put)...
if not.....then there has to be a mistake...
if it reads a voltage thats too low..then you AVR card is burnt out (AVR card is located in the other end of the generator (beyond the stator-side cover)...
Testimonial: "Khan sb. truly is a professional. "
