Question about Kipor Electrical Supplies
KIpor generator overload light comes on after starting ?
Posted by Bill Jenks on
Generator Guru Parts
    Master:
  • 269 Answers
We have a whole Help Center dedicated to helping people fix their Kipor and other Brand Portable Generators. Check it out on our site. https://www.generatorguru.com/
Parts Spares for Generators and Small Engine Machinery
Posted on Aug 19, 2019
Joseph Paco
    New Friend:
  • 63 Answers
Check for short circuit or wrong wiring
Posted on Aug 17, 2019
  • Joseph Paco
    Joseph Paco Aug 17, 2019
5 Related Answers
CarlGehrke
Carl Gehrke
  • 169 Answers
SOURCE: Problem with a kipor 12 ta generator
I just guessing here but it could mean that the oil pressure is too low.
I'd check the oil level first, then look for the oil pressure switch and temporarily disconnect it.
Regards,
Carl
Posted on Feb 23, 2009
4stevetaylor
  • 62 Answers
SOURCE: Kipor 3000ti generator, doesn't start, i checked
Drain carb bowl it could have water in the gas
Posted on Apr 07, 2009
Anonymous
  • 7 Answers
SOURCE: I have a Honda 7000 EM inverter generator. When it
ARE SURE ITS THE OVERLOAD LIGHT AND NOT THE NOIL ALERT? IF ITS THE OIL ALERT ITS CAUSE YOUR LOW ON OIL OR THE SENSOR INSIDE THE GENERATER IS BAD?
Posted on Sep 10, 2009
mike butler
  • 6468 Answers
SOURCE: kipor generator starts ok but will not provide electricity to apppliances
first check the circuit breakers if there ok the problem is inside like over heated parts
Posted on Sep 08, 2012
dustydis
vegas devildog
  • 373 Answers
SOURCE: kipor ig6000 overload alarm
most warning and alarm's are set less than what the manufacture rating is. it's a safety feature without it we would overload all our stuff
Posted on Sep 23, 2012
My kipor KGE 6000 Ti generator overload light is on, and there is no current output.
Read the instruction manual. If you are certain you did everything right and the generator does not behave as intended then return it to the supplier as faulty.
Jan 27, 2018 | Kipor Electrical Supplies
Kipor generator shut off after start with over load light.
Check your load and reduce if is more than the generator can handle.
Mar 13, 2017 | Kipor Electrical Supplies
My Kipor KDE16STA3 shows p03 error after 15 min runing and shuts down after 3 sec.The voltage drops to 30,40 whta's happening?
[PDF]DIESEL GENERATING SET
www.kipor.com/upload/spec2011053011590766.pdf
3/KDE16STA3/ ..... P-03 Undervoltage: Indicating voltage higher (lower), the generator will self- braking. P-04 Generator ... KDE16STA3 KDE19STA KDE19STA3.
[PDF]2
www.kipor.com/upload/spec2011061109073968.pdf
P-03. Decrease load less than the related load, turn on the breaker. P-04. Replace the fuse of the same type. Check the circuit and inserter. Replace the starting ...
Oct 31, 2015 | Kipor Electrical Supplies
The generator starts but when i plug in something it overloads with only one thing plugged in and stops generating
what watt is the jenny and what whatt is the tool ur using are u drawing to much power ?
Oct 09, 2013 | Kipor Kge3500ti
Speak to us and we can help you diagnose this error.
Dec 25, 2012 | Electrical Supplies
Kipor ig6000 overload alarm
Sep 23, 2012 | Kipor Electrical Supplies
Kipor generator starts ok but will not provide electricity to apppliances
Sep 05, 2012 | Kipor RV Generator Sinemaster IG3000
My kipor KGE 1000Ti starts fine but after several minutes stops generating and the red overload light comes on, with the demand for power left connected and the generator still running electrical...
You may be UNDERLOADING the generator and it may be unstable with such a light load... see if it might behave running a heavier load... put a 100 watt light on it as a test,
Jul 25, 2010 | Electrical Supplies
Electrical Supplies Logo
180 people viewed this question
Top Kipor Electrical Supplies Experts
Vernon Taylor
Wayne McNeil
Robert Wooley
Robert Wooley
Are you a Kipor Electrical Supply Expert? Answer questions, earn points and help others
