Water Heaters Logo
A
Anonymous Posted on Aug 21, 2014
Ariston problems why does Immersion heater keep tripping
Gene Haynes
Level 3:
  • Water Heaters Master 5,391 Answers
  • Posted on Aug 22, 2014
Gene Haynes
Level 3:
Answers
5391
Questions
0
Helped
2606675
Points
14124
1 Related Answer
Anonymous
  • 7 Answers
  • Posted on Jan 29, 2010
SOURCE: my ariston electric hot water heater keeps
Tripping off at the water heater or at the breaker box?
Ariston water heater service center
Copy following link for Bosch Ariston water heater resources:
http://waterheatertimer.org/Ariston-water-heater-resources.html
You can fix this water heater yourself, or buy another under-counter water heater if tank is leaking because anode depleted.
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Ariston troubleshooting
Copy following link for Ariston water heater resources including manuals, parts and troubleshoot:
Check if element is leaking. Replace water heater.
Water heater tripping the breaker
Copy following link for troubleshoot walk-thru for electric water heater tripping breaker:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#trip-breaker
1helpful
3answers
My rheem 50 gal water heater model 81mv52d keeps tripping the breaker, what do i need to do to stop this
Check all wiring at water heater and possible upper thermostat is bad, and in need of replacement.
My Ariston 4 gallon water heater is given out hot dirty water?... Any Suggestions?
1) Dirty water implies degraded metal inside unit:
The anode rod protects metal parts. Once anode is depleted, metal parts react with water.
2) Open following troubleshoot pdf showing Ariston parts
http://waterheatertimer.org/pdf/How-to-Troubleshoot-Bosch-Ariston-Water-Heater.pdf
3) Ariston manual: Read manual cover to cover, make sure water heater receives yearly maintenance as outline in manual.
http://waterheatertimer.org/pdf/Bosch-GL_English.pdf
4) Information on anode rods
http://waterheatertimer.org/Replace-anode-rod.html
5) For Bosch gas and electric tankless: Open following link for troubleshooting resources, including Bosch contact information, typical manuals, error codes, tech support, parts, fuel-saver calculator, service bulletins, water heater forum, fixya links, disclaimers, and links for finding service technician.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
6) Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Ariston GL6 less than two years old. Water does not get hot.
Troubleshoot Ariston GL6 6-gallon
I have recently had a Howden domestic immersion
I would not have both on at the same time . We never did .
1helpful
Top Water Heaters Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Water Heater Expert? Answer questions, earn points and help others
