Dear friend first Check the Ram try with another one. if it is not
2. May problem with Your Hardware like pci cards, hard drivers. remove those pci cards then try again.
3rd possibility is Your IDE or SCSI or SATA cables ARE DEFECTIVE OR PROPERLY NOT CONNECTED.
4th Possibility is Check Your hard disk
This means that your hard drive is bad. You need to replace your hard drive.
Hi Stefi,
An unmountable boot volume error means that the operating system cannot boot from the hard drive either because the boot files are corrupted, the hard drive is faulty or there is a problem with the cable connecting the hard drive to the computer. If you are booting your PC and come across a Blue Screen of Death stating UNMOUNTABLE_BOOT_VOLUME, don't despair.
You would need to repair the volume inorder to fix this issues.
To repair the volume, follow these steps:
