SOURCE: Pilot light has gone out onmy Ideal Elan 2 Boiler
TAKE A SHPO VAC AND CLEAN AREA. MAKE SURE YOU PAY SPECIAL ATT. TO THE PILOT LIGHT. FIND BUTTON HOLD IN AND IGNITE DONT LET GO WHEN IT LIGHTS FOR AT LEAST FIFTEEN SEC.. YOU MIGHT ALSO HAVE TO TURN THE THERMASTAT OR KNOB TO PILOT FIRST. AFTER IT HAS LIT TURN UP FLAME
SOURCE: pilot light on boiler
The plumbers repair should be guaranteed, give him a call back.
It sounds to me that the pilot flame needs to be adjusted or the thermocouple is not aligned properly or there is a draft that is blowing out the pilot.
Good luck...
SOURCE: how do you light a ravenheat pilot light
push in the yellow or grey button on the gas valve and click the piezo ignighter repeatedly keep the gasvalve button depressed for 20 seconds and the boiler should light if it does not you have a fault come back for more advice if this happens
SOURCE: We have a Wickes balanced flue 65F boiler.The
I would suggest that you check all wiring connections to gas valve, ignitor induced drarft motor if so equipped, flame sensor and thermostat . It sounds to me like you probably need a new ignitor. As for the leak see if you can isolate where it is coming from. You may have to remove some of the casing to find it. It may just be a loose fitting that can be removed taped with teflon tape or coated with pipe thread compound and reinstalled. It is nearly impossible to tell how hard the repair will be until you know the source. Hope this helps. Thanks
Testimonial: "Thanks for the amazingly quick response. The answer is succinct and not overly technical. Thanks very much."
SOURCE: Combi boiler (vailant), pilot light not igniting;
hi there
does the fan start up?
sounds like a faulty gas valve. has there been an interuption in your gas supplie?
hope this steers you in the right direction
Testimonial: "The feedback is very helpfull. Kind Regards Tracey"
