g
gill marsden Posted on Aug 12, 2014
How do i stop my alarm going off at midnight?
I have 2 of these & they both do the same - there is only 1 alarm function & I have tried resetting.
Scarlett
Level 1:
New Friend:
  • Contributor 10 Answers
  • Posted on Aug 12, 2014
Scarlett
Contributor
Level 1:
New Friend:
Answers
10
Questions
Helped
4089
Points
12
What's the exact brand and model? Most have a switch somewhere on it to shut off the alarm COMPLETLY.
1 Related Answer
Anonymous
  • Posted on May 04, 2008
SOURCE: midnight alarm feature never seen before
I am having the same problem. IT's so weird because I had owned the radio for many years before this ever happened for the first time? I unplugged it and this solved the problem for several months and again all of a sudden I am woken up every morning at 1 am. Any long term solutions?
My Emerson clock buzzer goes off at midnight every night How do I stop this from going off every night. I set the alarms to play music How do I stop the buzzer from going off at Midnight
If anyone has an idea I would value the input. Thanks
You can try resetting your clock's settings every night and ensuring that you set the time one minute before midnight. This should prevent the buzzer from going off at midnight. If that doesn't work, try unplugging it for a few seconds and then plugging it back in to reset the clock. You could also try using a dedicated outlet for your clock, so nothing else is accidentally interfering with its timer setting. Finally, you could try replacing your current clock with a new one if none of these solutions work.
1helpful
How do I use the buttons in this QHY watch?
Hopefully, this will help...
Lego Watches Manual Instruction:
There are 4 buttons on this lego watch case, Light button, Mode button, Stop button and Reset button, now I will show how to set the time easily!
1, Light Button: Press this button, the watch LCD light will display for 3-5 seconds;
2, How to use the stopwatches chronograph function?
Answer: When the lego watches in normal working condition, Press "Stop button" for 1 time, then the watch goes into the chronograph mode, then you can use "Stop button" and "Reset button" to operate this function.
3, How to set the alarm time?
Answer: When the lego watches in normal working condition, Press "Stop button" for 2 times, then the watch goes into the alarm mode, then you can use "Stop button" and "Reset button" to set the alarm time, also you can turn off or turn on the alarm function and chime on every hour function by the same operate.
4, How to set the right watch time, hour, minute, second, week, date, month, year?
Answer: When the lego watches in normal working condition, Press "Stop button" for 3 times, then the watch goes into the time setting mode, then you can use "Stop button" and "Reset button" to set the second, minute, hour, week, date, month and year.
This is all. So now please have a try to set your lego watches time!
Dec 06, 2014 • Watches
MX300 waste ink full
1) With the machine power turned off, while pressing the Stop/Reset button, press and hold the ON/OFF button. (DO NOT release the buttons). The Power LED lights in green to indicate that a function is selectable.
2) While holding the ON/OFF button, release the Stop/Reset button. (DO NOT release the ON/OFF button.)
3) While holding the ON/OFF button, press the Stop/Reset button 2 times, and then release both the ON/OFF and Stop/Reset buttons. (Each time the Stop/Reset button is pressed, the Alarm and Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED
4) When the Power LED lights in green (and "ServiceMode Idle" is displayed on the LCD), press the Stop/Reset button the specified number of time(s) according to the function listed in the table below, then press the ON/OFF button. (Each time the Stop/Reset button is pressed, the Alarm and Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED
1) In the service mode, press the Stop/Reset button 4 times to enter the ink absorber counter resetting mode
2) In the ink absorber counter resetting mode, press the Stop/Reset button the specified number of time(s) according to the kind of ink absorber whose value should be reset to 0%.
7helpful
2answers
Samsung gt c3312 alamr at 12 midnight . how to deactivate
my Samsung gt-C3312 phone has alarming at 12.00 AM and 4.40 AM while phone alarm deactivate. however, I reset master setting.
46helpful
4answers
Iam using SAMSUNG champ DUOS ( GT-E2652) phone. its alarm is automatically ON every day @ 12noon. how i stop that
i encountered the same issue, its alarm every 12 midnight. what i did is a created a dummy alarm.
from the menu... go to alarm icon, create/set alarm an 12:00am, you can set it to everyday, or select any other options. once you done.. save the settings.
next, do not make this alarm settings active.
11helpful
4answers
How to switch auto alarm on and off just how to set alarm and disable and enable product is a sainsburys red dab clock radio not the one with docking station
Dont know how to set the time for the alarm, but to switch it off press and hold the menu button until it asks if you want to reset the radio and then follow the instructions. It means you have to reset radio every time but at least it stops pesky alarm going off...
1helpful
2answers
12 hour vs 24 hour read on clock
Push the "mode" button twice to enter the time change function. Once the display is blinking keep pushing the mode button until you see the "pm" icon on the LCD display. When that happens set the clock as you normally would using the 1-4 keys.
Remember to check if the 12 hour clock is set to AM or PM.
Good luck.
GES050
unplus the radio and take out the batteries for like 10 min...once the machine resets the alarm will stop going off. The same thing happened to mine and this solved it.
 Grubhead
Grubhead
SmartAviator
SmartAviator
