My clock radio goes off every night at midnight. There is no way to shut it off. Our alarm is set for 6:30 am, not midnight. How can we stop the clock radio from doing this?
Start by adjusting the volume down to an acceptable level.
The mere fact that midnight is the HOUR of YOUR SCHEDULED assault... means you have SET the TIME but have never set the ALARM clock... and are using it mainly as a clock only... Yes?
Not as a radio... (I don't know your model... but most radio alarms are at your regular listening volume... (my sheltered opinion)).
(trying to be Sherlock here).
So you probably have your
ON - Off - Radio - Alarm selector switch set to RADIO... Yes?
I'm guessing... That is the problem.
When you want to listen... use the sleep or on buttons... or the "ON"
If I am off the mark... "comment" back to me with the MODEL & MAKE... and I'll give it a better going over.
If anyone has an idea I would value the input. Thanks
You can try resetting your clock's settings every night and ensuring that you set the time one minute before midnight. This should prevent the buzzer from going off at midnight. If that doesn't work, try unplugging it for a few seconds and then plugging it back in to reset the clock. You could also try using a dedicated outlet for your clock, so nothing else is accidentally interfering with its timer setting. Finally, you could try replacing your current clock with a new one if none of these solutions work.
I had the same problem - alarm going off at midnight. Hold down the Menu and Select buttons at the same time to reset the radio. This removes the alarm. It will rescan and find all digital stations again but you will lose any presets.
You probably have an alarm feature on the radio. The common default time for timepieces is 12:00. Find the alarm setting and set the alarm off. If you cannot turn it off set it for 11 am.
Dont know how to set the time for the alarm, but to switch it off press and hold the menu button until it asks if you want to reset the radio and then follow the instructions. It means you have to reset radio every time but at least it stops pesky alarm going off...
Look at the display. Look for a number 1 or a number 2 to determine which alarm is on. If you see a number 1, push the 1 button on the top right side of the alarm clock until the number light goes off (1 or 2 times, depending on whether it is set to beep or radio alarm). When the number is not lit up, the alarm is off.
