My remotes for my Buick will not work at all . what must be done to get them in working order again?
Close all the vehicle doors.
Insert the ignition key into the ignition lock cylinder.
Press and hold the DOOR unlock switch.
While holding the DOOR lock switch in the unlock position, cycle the ignition ON, OFF, ON, OFF.
Release the DOOR unlock switch. The doors will lock and unlock to confirm the program mode.
Press and hold the LOCK button and the UNLOCK button simultaneously on one keyless remote. After a delay of approximately 15 seconds , the doors will lock and unlock to confirm the programming of that transmitter.
Repeat the previous step to program up to four transmitters.
Turn the ignition switch to the RUN (one more click forward) position in order to exit the keyless entry transmitter mode.
Operate the transmitter functions in order to verify correct system operation
SOURCE: focus remote key fob not working
this info would cost you £30.+ at ford Radio
Frequency Programming Instructions:
SOURCE: remote key fob will not work-battery replaced
VW/AUDI/SEAT/SKODA
Remote Control Programming (1997 ON)
Procedure
1. Switch Ignition ON and leave the key in the ignition.
2. Mechanically lock the vehicle using the Drivers door using a second
key.
3. Using the remote control press the Unlock button once, and the horn
will sound once.
4. Wait 6 seconds and press the unlock button once to activate the coding
procedure. The remote control will now be programmed.
NOTE : When performing programming on additional remotes the procedure
is the same, except you press the unlock button 2, 3 or 4 times for the
different remote.
For example : If programming 2 remotes press the unlock button twice with
a 1 second interval between each press, repeat for 3 and 4 remotes.
5. Switch Ignition OFF.
6. Remove key from ignition and check for operation.
7. The coding procedure can be repeated up to 4 times for additional remotes.
8. The ignition must be switched OFF between programming each remote
control.
Remote Control Erasing (1997 ON)
Procedure
key.
3. Press the remote control unlock button 5 times in 1 second intervals.
A short horn will sound.
4. Wait 6 seconds and press the unlock button once to activate memory
erase.
5. Switch ignition OFF, all remotes are now erased.
SOURCE: renault megane key fob wont work
I had the same problem with mine
your key fob is now out of sync with the ECU to sync them just follow this link (renault will charge up to £180 for new key and to sync it)
http://renaulthelp.110mb.com/ImmBypass.html
SOURCE: remote key fob does not unlock or lock car
It may just be a battery problem. Replace the battery of your remote fob. If it will not work, try to reposition the controller beneath the dashboard.
SOURCE: programing instructions for buick 2006 lacrossekeyless remote fob
Transmitter ProgrammingImportant:
All transmitters which are to be recognized by the remote control door
lock receiver (RCDLR) must be programmed in a single programming
sequence. If the system is placed in program mode it will erase all
previously programmed transmitters upon the receipt of the programming
signal from the first transmitter. Up to 4 transmitters can be
programmed. Do not operate or program the transmitters in the vicinity
of other vehicles that are in the keyless entry program mode. This
prevents the programming of the transmitters to the incorrect vehicle.
Good luck
If
the remote s faulty then key fob will not get programmed.
Insert
the key in ignition. Turn the key to on position, and cycle the key three times
off-on-off-on-off-on. Then with the key fob remote select your remote and then
try to operate the vehicle with remote.
These
are just the basic procedure, but sometimes it will not help.
On
that case dealer is the only option.
There
are few much related troubleshooting links mentioned below for remote key fob reprogramming.
I suggest you to go through the list and click the link below to go through its
details and procedure: -------
http://technoanswers.blogspot.in/2012/02/theft-indicator-not-letting-car-to.html
http://whatisbyme.blogspot.in/2012/05/2009-toyota-highlander-smart-key-not.html
http://whoisbyme.blogspot.in/2012/07/pin-that-holds-flick-key-part-to-key-fob.html
http://technoanswers.blogspot.in/2012/04/2006-toyota-hilux-programming-new-key.html
http://technoanswers.blogspot.com/2012/01/where-is-key-chip-memory-located-on.html
http://schematicsdiagram.blogspot.com/2011/12/ford-keyless-remote-fob-reprogramming.html
http://schematicsdiagram.blogspot.com/2011/12/after-getting-car-washedcheck-engine.html
http://technoanswers.blogspot.com/2011/12/audi-a8-key-fob-programming.html
http://technoanswers.blogspot.com/2011/12/olds-aurora-key-fob-reprogramming.html
http://technoanswers.blogspot.com/2011/12/buick-lesabre-key-fob-reprogramming.html
http://technoanswers.blogspot.in/2012/01/keyfob-remote-not-working-on-2003-ford.html
http://technoanswers.blogspot.in/2012/02/key-will-open-doors-but-not-start-on.html
http://technoanswers.blogspot.in/2012/02/key-fob-will-not-lock-and-unlock-doors.html
http://whoisbyme.blogspot.in/2012/07/2012-dodge-ram-ignition-key-will-not.html
These
details will help.
Thanks.
KEYFOB PROGRAMMING
If
Insert
These
On
There
These
details will help.
Thanks.
----------After getting car
washed, check engine light is ON and key less entry not working, tried
reprogramming. Also car shows fuel pressure?
-----------Audi A8 Key Fob Programming?
Oldsmobile Aurora Key Fob Reprogramming?
Buick Lesabre Key Fob Reprogramming?
Keyfob remote not working on 2003 Ford E350 Econoline?
KeyFob will open the doors but not start on BMW?
Mitsubishi Car Key Not getting detected after replacing ECM
http://repairhelpcenter.blogspot.com/2012/11/mitsubishi-car-key-not-getting-detected.html
Key Fob will not lock and unlock doors?
2000 Jeep Cherokee Limited: KeyFob Remote Not
Working?
http://schematicsdiagram.blogspot.in/2012/06/2000-jeep-cherokee-limited-keyfob.html
Chevrolet Malibu: Key Stuck in ON position?
http://technoanswers.blogspot.in/2012/04/chevrolet-malibukey-stuck-in-on.html
Theft indicator not letting car to start?
2012 Dodge Ram: Ignition Key will not
release?
These details will help.Thanks.
